Fuel and Volt gauges stopped working... - Road Glide Forums
 4Likes
post #1 of 32 (permalink) Old 11-24-2015, 07:27 PM Thread Starter
! rock103 !'s Avatar
Fuel and volt gauges stopped working randomly today. Lights to the gauges also not lighting up to the fuel and volt gauges. I checked fuses, connections to gauges, handlebar etc. Bike starts runs fine, radio works, speedo tach work, no check engine light. Turn signals and joysticks work. Im at a loss at this point...what say you Guru's??
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #2 of 32 (permalink) Old 11-24-2015, 08:41 PM
Kind of odd, the lights for the gauges and the sensors are on different connectors for the gauges. Only thing they seem to have in common is being located towards the top of the fairing. I can't imagine you hit a few bumps really hard and jarred them loose? Have you ever had the fairing off? If not, it seems you may need to take a look, I can't think of another way to trouble shoot without removing the fairing. Maybe someone else will chime in who knows something I don't.
post #3 of 32 (permalink) Old 11-24-2015, 08:43 PM Thread Starter
Checked all the connections under the fairing. All good
post #4 of 32 (permalink) Old 11-24-2015, 08:44 PM Thread Starter
lights for speedo/tach and those gauges are working fine. Along with radio
post #5 of 32 (permalink) Old 11-24-2015, 08:48 PM
Mike U's Avatar
Rock, did you check ALL the fuses with a test light?
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #6 of 32 (permalink) Old 11-24-2015, 09:05 PM Thread Starter
Don't have a test light...but check to see if any where blown- nada, all good
post #7 of 32 (permalink) Old 11-24-2015, 09:32 PM
Mike U's Avatar
Rock, it's easy to miss a blown fuse just by checking by eye.
I would check all the fuses with a test light just to make sure they are all good.
After that, I would pull the main fuse for 30 sec. to a minute then replace it to see if that resets everything.
If that doesn't work I would make sure that you have power and ground to the gauges and lights that aren't working.
Hope this helps.
Mike U.
dbell66253 likes this.
USMC 1975-1977
Semper Fi!
post #8 of 32 (permalink) Old 11-24-2015, 09:40 PM
jeff338wm's Avatar
Check the ground
Smarty likes this.
'13 FLTRX Candy Orange w/ an upgrade here or there
jeff338wm is offline
post #9 of 32 (permalink) Old 11-24-2015, 09:55 PM Thread Starter
Thanks brothers...gonna rest on it and go at your suggestions with fresh eyes and mind tomorrow...Consulting with Jack Daniels for awhile and he says try tomorrow.
post #10 of 32 (permalink) Old 11-25-2015, 12:01 AM Thread Starter
Well I couldn't resist. Had the gf drive me to the parts store and got a fuse tester and fuses. Grabbed a k&n oil filter while I was there. 5k is due. Anyway I tested all fuses. All tested good. Grounds and connections checked again. All solid connections.
Fuel and Voltage gauge stopped working ronniekuiper *General Road Glide Discussions/Pictures 3 03-05-2018 12:42 PM
SOLD. FS: 2017 RGS Gauges (Fuel, Volt) SOLD. PSUUUUU Parts for Sale 9 10-05-2017 10:12 PM
Hit a pothole and Stereo stopped working? Thomas1369 Audio 2 10-21-2013 01:25 PM
cruise contol stopped working dhhen Troubleshooting for Road Glides 21 04-17-2012 04:29 PM
Horn Stopped Working FLTRXS20 Troubleshooting for Road Glides 12 11-08-2010 07:35 AM
