Channel trim b/w inner and outer fairing - Road Glide Forums
post #1 of 19 (permalink) Old 10-01-2010, 09:45 PM Thread Starter
Gadgetech's Avatar
When sitting on the bike the u shaped black channel trim that fits b/w the inner and outer fairing on the left side keeps coming out. I've pushed it back down several times and while my bike is brand new, I don't know if I trust the dealership to repair it. I loosened the inner fairing and pushed it down as good as possible. Has anyone else experienced this small problem and if so, how did you correct it?
Gadgetech is offline
post #2 of 19 (permalink) Old 10-01-2010, 10:41 PM
JacktheBagger's Avatar
very common issue
trying super glue this time around , just bought another set of them ..
talked the guy into charging me for one instead a two
used ta come inna pack of two for about ten smacks
now they inna pack of one for ten clams
2011 Ultra
JacktheBagger is online now
post #3 of 19 (permalink) Old 10-01-2010, 10:48 PM
Roadie09's Avatar
It is best to take care of the problem early. I kept pushing mine back on like you are doing and when summer came and the temperature hit 100+, whatever type of glue that is just oozed out all over the place. The glue does not ever get hard. I cleaned all of the OEM glue off and stuck the trim back on with black rtv, it has been on for 20K miles so far.
The should de-nut whoever picked that adhesive for that application.
Roadie09 is offline
post #4 of 19 (permalink) Old 10-01-2010, 10:49 PM Thread Starter
Gadgetech's Avatar
You took off the entire trim, cleaned it and then put black RTV on or just on the ends?
post #5 of 19 (permalink) Old 10-01-2010, 11:19 PM
jbrushoe's Avatar
Black RTV sounds like a good fix I'm guna give it a try. I have the same problem.
06 Shark Fire Red Pearl
1997 FLSTS > looking for a new home
Jim
jbrushoe is offline
post #6 of 19 (permalink) Old 10-03-2010, 01:25 AM
EasternSP's Avatar
if you buy the door edge strip at an auto parts store it works better and looks better and they are much cheaper. Put the glue on the inside edge of the fairing and it won't oz out.
Ken,
- 2006 RG 107/DD6/FatBagger 200mm Rear end w/Car tire
- 2016 RGU with Car Tire
EasternSP is offline
post #7 of 19 (permalink) Old 10-03-2010, 08:03 AM Thread Starter
Gadgetech's Avatar
Is the car door edging thicker/wider than what's there?
post #8 of 19 (permalink) Old 10-03-2010, 09:41 AM
Roadie09's Avatar
This is correct, I cleaned the original glue from the fairing and inside the channel trim then put a very thin bead around the fairing edge. I did not have any ooze out, but it could happen if excessive rtv were used. I do not think it would be hard to clean off the excess before it dries, so that should not really be a problem.
Roadie09 is offline
post #9 of 19 (permalink) Old 10-04-2010, 07:44 AM
HD-DOC's Avatar
Why not just remove the trim piece all together, and put it back together. The inner and outer fairings really have no seal anyway. Doc
HD-DOC is offline
post #10 of 19 (permalink) Old 11-01-2010, 06:30 AM
ITOLDU's Avatar
Ditto, I have had the new replacement strips both for 9.99 each for almost a year now and yet to put them on. It seems like just when I think it is not going to start coming out or apart it does while I am riding......You know it is bad when the woman says something ... I will try the Black RTV
ITOLDU is offline
Best outer / inner fairing trim? chevjerico *General Road Glide Discussions/Pictures 11 12-01-2017 07:17 AM
OUTER FAIRING and INNER FAIRING Big Daddy Recon Parts for Sale 13 08-24-2014 11:42 AM
Trim between inner and outer RG Willie Paint & Bodywork Section 27 03-20-2014 09:22 PM
Inner/Outer Fairing Trim phillyrube Paint & Bodywork Section 6 03-26-2012 12:48 AM
