2009 wont start - Road Glide Forums
 3Likes
  • 3 Post By FrankieB
post #1 of 6 (permalink) Old 01-18-2016, 04:38 AM Thread Starter
2009 wont start
Everything works, fuel pump lights. Hit start button and does nothing. Security lights don't stop blinking. Is there a reset? Dealer suggested key fob battery dead, I replaced still nothing. Any suggestions ? Than you.
raven006 is offline
post #2 of 6 (permalink) Old 01-18-2016, 07:11 AM
09Sharknose's Avatar
Try the manual security overide sequence. It's in your manual. Sounds like maybe the bike doesn't recognize the key is present.
09Sharknose is offline
post #3 of 6 (permalink) Old 01-18-2016, 11:03 AM
Since the fuel pump works did you check for spark? If there is no spark then you need to chase down the problem.
If have spark and you have a tuner on the bike try unhooking it and see if the bike starts then.
post #4 of 6 (permalink) Old 01-18-2016, 12:05 PM
FrankieB's Avatar
If your fuel pump is pressurizing then it isn't the fob or security related. The first thing to check would be the battery, you need to load test it then I would look at the fuses, I would pull them and check for continuity with a multimeter. I have seen them where they looked good but when tested they where blown. If all the fuses are good then I would replace the starter relay, take it to an autoparts store and they should be able to match one up. After the relay then have a look at your starter button.
ironmark, RGKen and bigr545 like this.
06 RK
11 RGU
FrankieB is offline
post #5 of 6 (permalink) Old 01-18-2016, 02:54 PM
I must of missed he part where it wasn't cranking over.
There is the small wire going to the back of the starter which comes from the starter relay if that wire is faulty or there is a bad connection the starter will not work at all, check that wire connection then if all the connections are good then check the starter relay.
post #6 of 6 (permalink) Old 01-18-2016, 04:54 PM
Triplej's Avatar
Try another FOB Battery from another batch and make sure you have it in right side up. My bet is you got a new battery that is not so new.
Had the same problem with member Harleyagain's bike in my driveway. He told me he just replaced the FOB battery and it kept doing it.
I took the battery out of my FOB stuck it in his FOB and bingo, his bike fired right up. His new battery was crap.
Just to double check about the fuel pump not pressurizing I checked all 3 bikes in my garage at the moment and all 3 pressurize the fuel pump with no FOB present, lights were flashing and nothing happens when I hit the starter.
It is worth a try and I hope it is that simple for ya.
Triplej is offline
Bike wont start Bluchevypick Troubleshooting for Road Glides 50 01-26-2014 01:15 AM
changed handle bars wont start now rob883 Controls & Handlebars 11 05-06-2013 08:57 AM
2012 RGU wont start after cam swap Bluchevypick Troubleshooting for Road Glides 5 04-20-2012 11:35 PM
changed bars now bike wont start NO4NBIKES Controls & Handlebars 4 01-02-2012 11:06 AM
wont start The instigator Road Glide Specific Discussions 8 03-24-2011 10:20 PM
