Rattling Noise at high RPM - Road Glide Forums
post #1 of 6 (permalink) Old 02-28-2016, 06:18 PM Thread Starter
Bleachey's Avatar
Ok, 2011 RGU, just under 38k miles. Stock other than mufflers and plugs/wires. Went out for a ride today and when I got on it hard heard a rattling noise in 2nd and 3rd when the RPM's got up around 4k. Couldn't replicate it when not rolling, when in neutral or when at a stop with the clutch in it wasn't there. Didn't try taking it that high in 4th and didn't really notice in 1st. Any ideas?
2011 Road Glide Ultra
Bleachey is offline
post #2 of 6 (permalink) Old 02-28-2016, 07:22 PM
sj01fltri's Avatar
These types of noise can some times be hard to track down because they are hard to reproduce.I have a squeak at idle only while the front brake is applied think it in the exhaust system some where.Check all your heat shields first then all your floorboards or pegs could be something simple.
sj01fltri is offline
post #3 of 6 (permalink) Old 02-28-2016, 08:31 PM
Spazz's Avatar
How much of a load is on the bike when you hear it? Could it be detonation? How is your oil level/PSI?
RENO BAGGER AUDIO
Spazz is offline
post #4 of 6 (permalink) Old 02-28-2016, 08:41 PM Thread Starter
Bleachey's Avatar
Oil level is good and PSI is good. It only happened when I was on it pretty hard, prob 3/4 throttle getting up to speed in a hurry. It did it two different times. Was talking to a buddy, this is only the third time I've had it out since November of last year. Might be old gas. I did fill it up today, I'm going to add some sea foam and run through the whole tank next chance I get to see if that might be the problem.
Bleachey is offline
post #5 of 6 (permalink) Old 02-28-2016, 09:04 PM
Nordic Berserker's Avatar
Sometimes the baffles rattle, specially in Vance & Hines mufflers. Nothing more annoying then rattles, I hope you figure it out without having to dig too deep
Nordic Berserker is offline
post #6 of 6 (permalink) Old 02-29-2016, 09:06 AM
Sounds like you may have a spark knock situation, if you do it is in the tune.
Rattling noise... headlight assembly? georgec *General Road Glide Discussions/Pictures 7 02-11-2016 05:31 PM
High RPM's, no acceleration Desert Dweller Troubleshooting for Road Glides 9 04-17-2015 11:00 PM
Rattling noise Timhogan Troubleshooting for Road Glides 6 03-27-2013 01:43 PM
Rattling noise Grapnel Troubleshooting for Road Glides 24 09-23-2012 02:11 PM
Engine noise at 45 RPM Traveller Troubleshooting for Road Glides 13 06-02-2011 10:42 PM
