Vibration RPM specific - Road Glide Forums
  • 1 Post By Smarty
post #1 of 6 (permalink) Old 03-12-2016, 01:14 PM Thread Starter
MShell's Avatar
I have a slight vibration that starts at 2800 rpm to 3000 rpm, it doesn't matter what gear or speed I'm going it starts at 2800 and will continue to 3000 rpm, if I'm under 2800 no vibration if I'm above 3000 no vibration. I've had no work or mods done recently, my bike is a '12 RGU with 76k miles, 574 cams but that was done at 30k miles.
The vibration does not seem to be coming from the suspension it feels more drivetrain related, I've checked all the mounts for tranny and engine and all is good there. Looking for anyone that has had any similar symptoms or thoughts on cause. I have not changed my primary chain tensioner so that was my first thought with the miles I have on it but, any thoughts would be appreciated
Lug nut rule, the one with the most lug nuts wins
MShell is offline
post #2 of 6 (permalink) Old 03-12-2016, 11:50 PM
miker717's Avatar
I had a similar vibration a couple years ago and that large bolt that holds the exhaust on was loose
2011 vivid black fltrx
miker717 is offline
post #3 of 6 (permalink) Old 03-12-2016, 11:53 PM
BlueBagger12's Avatar
1+ somethings loose and hasn't fallen off yet. Wrench test time.
Don't fail us now, oh blessed mother of acceleration...
BlueBagger12 is offline
post #4 of 6 (permalink) Old 03-13-2016, 03:03 AM Thread Starter
MShell's Avatar
I thought of the exhaust as well and checked it, everything tight there as well. Gonna throw it on the lift and go over everything
MShell is offline
post #5 of 6 (permalink) Old 03-13-2016, 10:39 AM
eddienelson's Avatar
Keep us posted.
2016 RG Custom Vivid Black
eddienelson is online now
post #6 of 6 (permalink) Old 03-13-2016, 11:15 AM
Smarty's Avatar
Mine ended up being the header rubbing on the floorboard. Cause: Front motor mount had worn and engine dropped down.
hotrodad likes this.
2016 RGS Black Quartz
Smarty is offline
2500-3000 rpm vibration mouser58 Engine Related 1 11-15-2016 03:59 PM
Installed Duals, Engine vibration Below 2000 RPM bosshogg123 ECM/Fuel Management systems 2 09-12-2016 12:55 AM
103 vibration above 3000 rpm after cams? baldwookie Engine Related 22 06-17-2016 07:17 PM
RPM Related Vibration Cuzen Engine Related 8 11-14-2013 06:36 AM
any specific brand head pipe louder than the rest?? Eshaw301 Intake and Exhaust 10 05-22-2012 04:50 PM
