F Me High Idle Woes - Road Glide Forums
 8Likes
post #1 of 24 (permalink) Old 03-14-2016, 10:11 PM Thread Starter
F Me High Idle Woes
Hi all,
I was hoping to get some advice...I have been experiencing on my 2010 FLTRX a high idle after engine warm up, i.e. 1800-2000 RPMs at idle with no return to normal idle. The bike has nearly 17K miles.
I have searched what feels like every corner of the internet for a solution. Based upon other solutions I changed the following: engine temp sensor, crank position sensor, both O2 sensors, checked for air cleaner leaks, cleaned my air cleaner, changed my exhaust gaskets, new battery, prayed to Madonna, you get the idea. Oh yeah I added dielectric grease to the plug that everyone says to do...sorry I don't remember if it was the tca plug but I think so. I have done all of this and still I have a high idle after a warmed up engine. I have checked the codes but that doesn't help, I do not get a check engine light nor does my bike go into limp mode. IDK what to do next other than to go to the dealership and experience what I know to be a $1K non-fix (pessimistic for a reason). Any advice is greatly appreciated.
John
johnd5412 is offline
post #2 of 24 (permalink) Old 03-14-2016, 10:51 PM
chilidogtampa's Avatar
Have you ruled out the the throttle? Like unplug the TBW connector at whatever connector its on under the fairing.
chilidogtampa is offline
post #3 of 24 (permalink) Old 03-14-2016, 10:52 PM
There is an idle relearn procedure but you also may want to check for a vacuum leak. If I'm not mistaken there's a lil rubber boot that can fall off and create a vacuum leak. I believe it's on the throttle body
post #4 of 24 (permalink) Old 03-14-2016, 11:15 PM Thread Starter
Is that the purge tube cap?
post #5 of 24 (permalink) Old 03-14-2016, 11:42 PM Thread Starter
not the idle relearn, tried it and no love....bike idles fine at startup until fully warm; then the high idle starts.
post #6 of 24 (permalink) Old 03-15-2016, 12:57 AM
JacktheBagger's Avatar
check the IAC , spray some seafoam or TB cleaner in there
2011 Ultra
JacktheBagger is offline
post #7 of 24 (permalink) Old 03-15-2016, 11:24 AM Thread Starter
The 2010's don't have an IAC or am I missing something?
post #8 of 24 (permalink) Old 03-15-2016, 12:07 PM
In most high idle situations you can cycle the ignition on/off 5 times and it will reset the idle to factory specs. A ignition cycle consist of turning the ignition on and waiting until the engine light goes off then turn the ignition off, if the engine light doesn't come on after a few on/off cycles wait until the red key light goes off.
The reason the bike idles high is because the ECM will remember the throttle position when the bike is turned off so basically when the engine is turned off when the idle is high then the idle will remain high until you cycle the ignition 5 times. That is why you need to keep the hands off the throttle and make sure the engine idles down before shutting the bike off.
I alway use the main ignition switch to turn the bike off and I use my right hand to do it.
post #9 of 24 (permalink) Old 03-15-2016, 12:11 PM
Swomack's Avatar
Thanks for posting up this information.
You just taught me something new.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #10 of 24 (permalink) Old 03-15-2016, 01:34 PM
I didn't know that either. Payed to wake up again today!
aviaator likes this.
2012 FLTRX, vivid black
sometimer is offline
Engine bucking, stalling, high idle, sputtering Taccone *General Road Glide Discussions/Pictures 31 02-23-2018 10:34 PM
High Idle dbell66253 Engine Related 23 12-01-2014 10:37 AM
Cold start high idle Cjk2013 Tech Area 6 04-23-2014 01:57 PM
07 flh high idle with 4 codes Bob0707 Engine Related 1 04-18-2014 05:36 PM
High idle ? BigDave55 *General Road Glide Discussions/Pictures 12 06-26-2013 09:24 PM
