Inner primary whirling noise - Road Glide Forums
post #1 of 5 (permalink) Old 03-15-2016, 06:22 PM Thread Starter
Wood's Avatar
2010 FLTRX with 55K miles with a whirling noise coming from the inner primary.
The inner primary whirling noise can be heard when the bike is idling and it is in neutral; the noise goes away when you hold in the clutch and drop the transmission into gear. Like others have noted, and as diagnosed by my local Indy, I have an inner primary bearing problem.
Well I just pulled the inner primary, clutch, etc. and took a few pictures of the inner primary bearing RACE that is located on the transmission shaft. In the pictures below you will see the overall RACE, and three different PITS that I found.
It also appears to me that the inner primary roller bearing rode on just the edges of the RACE instead across the full width; in the pictures you will see a dark area that runs around the entire RACE and is centered. This dark area appears to have no roller bearing wear marks at all. I expected to see roller bearing wear marks across the entire face or width of the RACE, not just the edges. Is this normal wear for this MOCO design?
The roller bearing itself doesn’t have any apparent defect, but it is harder to inspect than the RACE. The bearing SEAL was functional; it was not leaking.
Now to focus on replacing the RACE, roller bearing, etc., and getting it all back together.
Wood is offline
post #2 of 5 (permalink) Old 03-15-2016, 06:23 PM Thread Starter
Wood's Avatar
Two more PITS pictures.
Wood is offline
post #3 of 5 (permalink) Old 03-15-2016, 07:26 PM
mocotom's Avatar
I would not reassemble that primary without replacing the bearing. I use the Baker high torque bearing on all the primaries I work on, especially the later models with the primary chain auto-tensioner
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
post #4 of 5 (permalink) Old 03-15-2016, 10:31 PM
Definitely change the bearing before you put it back together. It would be foolish not to
post #5 of 5 (permalink) Old 03-16-2016, 10:52 AM Thread Starter
Wood's Avatar
Yes, the plan is to replace the RACE and the Roller Bearing. Was surprised to see that the stock Roller Bearing comes from Germany, INA is the mfg.
Wood is offline
Another Primary Noise Thread Pork Chop Troubleshooting for Road Glides 6 04-19-2015 06:34 PM
noise in primary???? craig demel Troubleshooting for Road Glides 4 07-08-2013 12:30 AM
Noise in the primary RoadGlide0611 Engine Related 9 05-25-2013 09:35 PM
whirling sound at about 2,500 rpm hd4cruzin Troubleshooting for Road Glides 3 05-10-2013 01:51 PM
Loud noise Primary Beachjeep Troubleshooting for Road Glides 12 11-20-2012 05:06 AM
