shifter pawl lever seal - Road Glide Forums
post #1 of 1 (permalink) Old 03-20-2016, 08:04 PM Thread Starter
Hello all, Jim from Niagara Falls here.2012 FLTRX 46000mi
just looking for some others thoughts of this subject, I replaced my shifter shaft seal at the beginning of last season, I used the James seal instead of stock, from reading that others said it was better, its leaking again and shaft appears to have .020 side movement, should be looking to replace entire shifter pawl and bushing in the trans case or just slap another seal in there?
thanks
exracer2002 is offline
Lever Change Kuryakyn Boss Lever 16RGS *General Road Glide Discussions/Pictures 9 03-31-2017 10:45 AM
Shifter shaft lever problems DED HD Troubleshooting for Road Glides 24 09-13-2013 01:28 PM
If the weather seal does not seal, what is the point?? Govdog76 Aftermarket Accessories 3 02-21-2012 09:48 AM
Shifter Lever. mkoziol3 *General Road Glide Discussions/Pictures 0 11-15-2010 05:51 PM
Faring Seal clsmoothnv Troubleshooting for Road Glides 6 03-28-2010 01:06 AM
