Finding and resetting Security Codes and Bipassing Security - Road Glide Forums
post #1 of 1 (permalink) Old 03-26-2016, 10:41 AM Thread Starter
RICKLB58's Avatar
Not sure if this is the right place for this so Mod can move it where ever is the best place but great info to have.
To reset the code with a TSSM equipped bike (with button fob), you will:
1) Set your kill switch to off
2) Quickly turn the ignition switch on, off, on, off, on
3) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
4) Press and let go of your fob button twice (press fairly hard, it's designed to resist being pressed by keys and whatnot in your pocket)
5) Current PIN number will be displayed on odometer
6) Change the PIN by pressing the left signal until the desired number is reached
7) Press the fob button twice to cycle to the next number and repeat step 7
8) Press and let go the right signal and turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 2 through 4 must be completed in quick succession of each other.
Now you can have the bike armed, and disarm with the PIN (example PIN will be 25522 in the following steps):
1) Ignition switch to Accessories
2) Immediately press both turn signals at the same time (red key light on you speedometer will flash rapidly if done right)
3) Press and let go the left signal 2 times
4) Press and let go the right signal once
5) Press and let go the left signal 5 times
6) Press and let go the right signal once
7) Repeat for each of the last three numbers of the PIN (left 5 times, right once, left 2 times, right once, left 2 times, right once)
8) Red key on speedo will stop blinking if done right (security has been disarmed)
NOTE: Steps 2 through 7 must be completed in quick succession of each other.
To reset the code with a HFSM equipped bike (no button fob), you will:
1) Have your key fob near the bike
2) Set your kill switch to off
3) Quickly turn the ignition switch on, off, on, off, on
4) Immediately press and let go of the left turn signal switch twice (press, let go, press, let go)
5) Press and let go the right signal once
6) Current PIN number will be displayed on odometer
7) Change the PIN by pressing the left signal until the desired number is reached
8) Press the right signal to cycle to the next number and repeat step 7
9) Turn ignition off when 5 digit PIN is satisfactory
NOTE: Steps 3 through 5 must be completed in quick succession of each other.
1) Ignition switch to on
2012 RGU, Thunder Max tuner, V/H power duals, Stage one, DayMakers, 12 inch F47 Malos, custom gages, and some extra chrome.
RICKLB58 is offline
Electronic Security Alarm Flashing and Security Alarm Chirping When Ignition Switch I aklowrider Troubleshooting for Road Glides 2 05-03-2016 03:26 AM
Checking/resetting security PIN Chuck1073 *General Road Glide Discussions/Pictures 10 07-15-2015 02:20 AM
Clock resetting randomly Monkeyballs Audio 2 07-19-2014 10:04 PM
Codes and more codes SmokeyJoe Troubleshooting for Road Glides 3 03-09-2014 01:56 PM
clutch lever travel and finding Neutral Spock Troubleshooting for Road Glides 5 09-13-2013 07:32 PM
