09 Roadie has miss on accelleration - Road Glide Forums
post #1 of 5 (permalink) Old 10-12-2010, 11:57 PM Thread Starter
71u140's Avatar
Bought this 2009 bike new last Feb (2010). Added SE stage 1 air cleaner, V&H slip-ons, and SERT (for future mods) at purchase. I internally wired and installed 10" Chubby apes about a month later. No problems until a couple of months ago at 7000 miles, when it started having an intermittent miss during accelleration. It happens whether I'm using the twist grip or the cruise/accellerate switch, hot or cold, at any speed, even when taking off from a stop. Usually, it's just a single miss, but sometimes it's several times in a row. It's intermittent, but getting worse. It's at the dealership now, but they're stumped. Any ideas?
'13FLTRX103, Pro Stage IV kit, V&H slip-ons, 10" Chubby apes, EG Ultra Tour Pak, RG lowers, more to come!
71u140 is offline
post #2 of 5 (permalink) Old 10-13-2010, 12:55 AM
KrashKatz's Avatar
Dirty Injector?
Intake Manifold Leak? (a shot of starting fluid, propane, or wd-40 around the manifold will let you know right away)
Coil going bad?
Plugs/Wires?
If it's upside down and burning, you've gone too fast.
KrashKatz is offline
post #3 of 5 (permalink) Old 10-13-2010, 08:05 AM
HD-DOC's Avatar
Change plugs and check your battery terminals.
HD-DOC is offline
post #4 of 5 (permalink) Old 10-13-2010, 08:21 AM
jupiter's Avatar
Do the 9's have the fuel line issue (inside the tank)
jupiter is offline
post #5 of 5 (permalink) Old 10-21-2010, 08:07 PM Thread Starter
71u140's Avatar
Dealership Techs found the starter cable pushing against the coil pack connector. Moved the cable slightly and replaced pins in the connector. Seems to have fixed the problem.
Haven't heard anything about the fuel line problem.
71u140 is offline
accelleration and deceleration slack somewhere waynemags Engine Related 12 10-27-2016 10:15 PM
my bike sometimes has a miss cape breton Troubleshooting for Road Glides 1 08-15-2015 08:47 AM
Did I miss a thread that has pics from shark week 5? Steelerdude1 *General Road Glide Discussions/Pictures 8 08-06-2015 09:52 PM
09+ Tour Pak Mount (53411-09) and Side Covers (L-47526-09, R-47522-09) bikerglasses Parts for Sale 3 12-06-2013 10:33 AM
OL says Roadie has a Problem JacktheBagger Troubleshooting for Road Glides 11 10-11-2010 09:59 PM
