steering - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 04-21-2016, 08:52 AM Thread Starter
steering
For awhile it has felt like if I go over the slightest groove in the road, I will lose control. I dont lose it but for that split second it feels it.
I have made sure my tire is properly inflated, and when I put my bike up on the jack, the fall away is within specs (the manual)
One thought I had was that maybe the steering is a bit loose, and the fall away looks good because levers (brake, clutch,) and instruments are still attached.
Any ideas?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 12 (permalink) Old 04-21-2016, 09:55 AM
VikingRider's Avatar
I would take it to a garage and have trained tech look at it. It would give you some peace of mind.
I had similar symptoms on my bike but mine is a 2001 SERG. I had the forks seals replaced and serviced with a new type of oil that made a huge difference.
FLTRSEI2
VikingRider is offline
post #3 of 12 (permalink) Old 04-21-2016, 02:23 PM
skratch's Avatar
are you measureing your fall away by the spec in the manual, or by the correct spec as per the tb? the tb lowers the number of swings to be in spec. mine is at 1 and i no longer have any 'shimmy' when i take my hands off the bars (i know, don't do that....)
Big_gary likes this.
skratch is offline
post #4 of 12 (permalink) Old 04-21-2016, 07:33 PM
How old are your tires ?
Big_gary is online now
post #5 of 12 (permalink) Old 04-21-2016, 10:55 PM
What year bike? I changed the front suspension to Progressive on both of my bikes, much better feel and handling.
post #6 of 12 (permalink) Old 04-22-2016, 08:42 AM Thread Starter
Bike is 2013. Original tires but only 7,500 miles
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #7 of 12 (permalink) Old 04-22-2016, 08:42 AM Thread Starter
"tb" ?
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #8 of 12 (permalink) Old 04-22-2016, 08:50 AM
BH#103's Avatar
Check for a belt that is shifting in the tire. Had this on my '12 and would give a feeling like temporary loss of control. Just an idea. Good luck!
BH#103 is online now
post #9 of 12 (permalink) Old 04-22-2016, 07:26 PM
skratch's Avatar
Originally Posted by pauld View Post
"tb" ?
technical bulletin.
look for m-1246 steering wobble
skratch is offline
post #10 of 12 (permalink) Old 04-23-2016, 11:02 AM Thread Starter
technical bulletin.
2009 only
2018 Road Glide
ABS. Boom Audio
pauld is offline
***2011 Steering Shake Issues*** smithdk130 Road Glide Specific Discussions 217 07-14-2015 08:21 AM
Steering Shake Survey by year 1BigGuy *General Road Glide Discussions/Pictures 43 01-29-2012 01:00 PM
2011 Road Glide steering head bearings bradj *General Road Glide Discussions/Pictures 5 02-12-2011 12:35 PM
2011 Road Glide steering head bearings bradj *General Road Glide Discussions/Pictures 0 02-11-2011 09:27 PM
Steering Damper for Road Glides Quick Aftermarket Accessories 13 01-27-2011 12:06 AM
