2016 ignition removal from the off position - Road Glide Forums
post #1 of 4 (permalink) Old 04-25-2016, 06:58 PM Thread Starter
I just ordered a set of chizeled lo bars and will be installing myself when they get here. I've watched the YouTube videos and read on here how to properly remove the ignition. However, the fork stays locked once the ignition is removed. I also read that there is an alignment tool to unlock the forks. Well I tried to remove the ignition from the off position and it worked fine. Plus the forks didn't lock. Will doing it from the off position hurt anything? Is it supposed to do this?
Wilks132 is offline
post #2 of 4 (permalink) Old 04-25-2016, 10:19 PM
bucketlisthd's Avatar
Too late, but there is no need to remove the switch. The chrome piece under it lifts off leaving a space large enough to work the speedo housing over it. Major improvement.
bucketlisthd is offline
post #3 of 4 (permalink) Old 06-07-2017, 12:34 PM
Does gas tank need removed to get plate off from under fork lock switch?
Tiny Glide is offline
post #4 of 4 (permalink) Old 06-07-2017, 02:20 PM
No tank removal is needed to get off but with switch in it is easy to break the tap.I just took mine off in off also did the bar change.Then put the switch back and it wouldn't come on.I turned it full lock and it all lined up then when i tried it came on.I got lucky i guess.
steve2100 is offline
2003 ignition don't move to pick position. Replace or upgradable? Biggredd2069 Troubleshooting for Road Glides 3 04-16-2018 11:00 PM
2016 RGS Wind from handlebar position houstonhdguy Windshields 0 04-18-2016 09:45 PM
2016 Road Glide Ultra passenger floorboard position maureend *General Road Glide Discussions/Pictures 11 11-16-2015 08:32 PM
Ignition switch out housing removal rsscoggins Controls & Handlebars 0 02-17-2015 06:37 PM
Ignition switch removal question dennisnyhc *General Road Glide Discussions/Pictures 3 04-11-2012 09:48 AM
