Engine/Trans Alignment - Road Glide Forums
post #1 of 4 (permalink) Old 04-27-2016, 05:26 PM Thread Starter
93-331-29psi's Avatar
I'm going to guess that this isn't a good indication of things being aligned properly. Ever since I've installed the 200 rear tire I have noticed that the belt occasionally makes contact with the tire while backing up and there's very little room 1/16" between the belt and tire going forward. Done some research and come to the conclusion that I have bad engine/trans mounts. Anyone else have an opinion??
Front engine mount
Swing arm bushings
Top Front engine mount unbolted
93-331-29psi is offline
post #2 of 4 (permalink) Old 04-27-2016, 06:50 PM
JacktheBagger's Avatar
I don't think it is an issue backing up .. Maybe wrong , could be wrong ...
2011 Ultra
JacktheBagger is offline
post #3 of 4 (permalink) Old 04-27-2016, 07:05 PM Thread Starter
You're right backing up the belt will track closer to the wheel but mine tracks to right in both directions.
The right side of the swing arm is higher and more rearward than the left side which I think (???) would cause Trans drive gear to track the belt to the right vice left, but I could be wrong.
Just looking for opinions before I drop $450 on new glide pro engine and transmissions mounts.
post #4 of 4 (permalink) Old 04-27-2016, 07:53 PM
'05Train's Avatar
Here's a great way to align the frame and the wheels. Check the motor mounts as well, but this will probably help too.
'05Train is online now
Chrome engine and trans take offs. tech643 Parts for Sale 4 10-10-2015 06:35 AM
Rear Wheel Alignment joke Wheels and Tires 12 08-10-2013 06:59 AM
Fairing - front fork alignment Tim Powell Troubleshooting for Road Glides 7 04-16-2013 10:10 PM
Nostalgic saddlebag guard alignment problem. JL Sargent Aftermarket Accessories 3 08-13-2012 07:27 AM
Header alignment Kevian Intake and Exhaust 2 07-18-2012 05:19 AM
