Clutch Cable to Tight-Lever Install - Road Glide Forums
post #1 of 5 (permalink) Old 04-28-2016, 09:19 AM Thread Starter
Hello-
Im installing new levers on my 2001 RG. I got the old clutch lever off and i have adjusted the cable to give me slack. I barely got the old one of because it was so tight. Now i cant put the new lever on because of this. Even with the lever off i dont have enough from the cable covering to the end of the cable to slide it through the slot on the control.
thank you
SNemet is offline
post #2 of 5 (permalink) Old 04-28-2016, 10:34 AM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
If you don't have enough cable you will have to adjust it from the derby cover and then do the complete re-adjust procedure.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #3 of 5 (permalink) Old 04-28-2016, 01:37 PM Thread Starter
So I'm going to have to take the transmission cover off and then buy new tranny oil and seal?
SNemet is offline
post #4 of 5 (permalink) Old 04-28-2016, 05:22 PM
lil chief's Avatar
But if the new levers are just stock replacements, there shouldn't be a need to dive into he tranny end of the cable.
Lil Chief
lil chief is offline
post #5 of 5 (permalink) Old 04-28-2016, 05:23 PM
No, I think EODHOG was referring to the adjustment made at the clutch adjuster screw. It's located behind the clutch inspection cover ie. derby cover.
2012 FLTRX, vivid black
sometimer is offline
DIY Install of Oberon Adjustable Clutch Lever paid4c4 *General Road Glide Discussions/Pictures 31 10-27-2018 03:19 PM
Changed clutch cable to +6 cable...clutch does not appear to engage backwaterdogs Troubleshooting for Road Glides 4 05-20-2017 08:09 PM
Need Help-Clutch Cable Lever Change-Tight Cable SNemet Controls & Handlebars 6 04-28-2016 05:42 PM
Brake and clutch lever install paulbeezie Controls & Handlebars 0 12-25-2013 10:35 PM
Brake & Clutch Lever Install jimmyray11349 *General Road Glide Discussions/Pictures 3 08-03-2011 10:29 AM
