2016 FLTRU lacks power over 3,000 rpm - Road Glide Forums
 4Likes
post #1 of 39 (permalink) Old 05-07-2016, 03:59 PM Thread Starter
gorillaman's Avatar
Yep... Brand new bike. Got it with 8km on the clock.
Now I have 300. But I have noticed excessive vibration in the tour pak at all speeds. Also when accelerating over 3,000 rpm (shifting)... or role on from 2,600+rpm the engine is lagging. Just does not sound right. Sounds kinda hollow or boggy??
I checked for codes... all are "None". I tightened all shock bolts and fender attachments. Tightened tour pak mount.
My wife noticed that the backrest vibrated uncomfortably at any speed. It was better at about 2,600 rpm but got worse again at 3,000+.
When accelerating with load the engine sounds hollow? All my other baggers were smooth all the way up to 4,000+. This one just feels rough.
Running to lean?? Throttle body leak??? Motor mount??? Front linkage? Exhaust gasket leak??
Ever heard anything like this???
bobbybones likes this.
2016 FLTRU Vivid Black
gorillaman is offline
post #2 of 39 (permalink) Old 05-07-2016, 04:36 PM
TYM2GLIDE's Avatar
Sounds like the dealership you bought the bike from has some work to do to make it right!
Big_gary likes this.
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #3 of 39 (permalink) Old 05-07-2016, 04:52 PM
Brent376's Avatar
Check that both plug wires are on properly
Sent from my HTC One_M8 using Tapatalk
JAWZ 2 / 2015 RGS /Custom Paint
Brent376 is offline
post #4 of 39 (permalink) Old 05-07-2016, 04:56 PM
lil chief's Avatar
Yep, make use of that factory warranty!
Lil Chief
lil chief is offline
post #5 of 39 (permalink) Old 05-07-2016, 05:49 PM Thread Starter
gorillaman's Avatar
I also feel that the idle is a little rough...
I have an appointment Monday Morning 10am for a quick inspection and a full appointment if needed for Thursday Morning.
A little odd I know... but I originally called and settled on Thursday . Then I went over the bike and found the rear shock bolts were not to torque. With a hand wrench I could turn the head almost a full turn. I called back for a torque spec and they said bring it in Monday and they would go over it and keep the Thursday appointment open if needed.
post #6 of 39 (permalink) Old 05-07-2016, 07:56 PM
kouack's Avatar
Wow so much for the pre delivery check
scooterh72 likes this.
kouack is offline
post #7 of 39 (permalink) Old 05-09-2016, 11:10 AM Thread Starter
gorillaman's Avatar
I did find a few bolts not torqued correctly but nothing that would cause the issues.
Simply put... On acceleration (roll on) from 2600-3100 rpm the bike has a very deep vibration right up through the handlebars.
If I change gears around 2700 rpm its not bad...and if I'm up over 3500 rpm it really pulls (only tried that a few times). But if you are cruising along at 2600 rpm and accel up through 3100+ ... the vibes are there.
Given this I'mm tending to think Throttle body???
It goes in on Thursday for a head to toe eval. If they say there is nothing wrong... they can keep it! ... If they find something obvious... I'll ask for the PDI back
post #8 of 39 (permalink) Old 05-09-2016, 11:14 AM
sh1520's Avatar
Probly a dumb thought here, BUT- I've got the same bike- And according to the Owners Manual, there's the "break-in" period the 1st 500 miles where you gotta keep an eye on the RPM's. I'm sure you did that, but maybe it has something to do with the problems? Luckily I'm not experiencing any of those issues
2016 FLTRU
Cobra NH Series 4.5" Slip-Ons "Neighbor-Haters"
16" HD Chizel bars/Willie G pegs, fuel and derby cover
sh1520 is offline
post #9 of 39 (permalink) Old 05-09-2016, 11:39 AM Thread Starter
gorillaman's Avatar
Good point.....
Yep... under 3,000 for the most part... mid range shifting... 2600 rpm. No prolonged rpm's. Short bursts up over 3,000 a few times on Accel.
It had 8km's on it when I rolled it off the lot. These issues were from the very first gear changes. I rarely go near 3,000 rpm. Its never been near 3500 yet. I did get up to 120 kph for a few seconds but then down to 110 (2700rpm). I think I read somewhere that at the 3,000 rpm mark something happens in the throttle body?? I have 460 km on it now. Most of that was country road riding at between 2500-2800 rpm up and down.
Its pretty good at those ranges... but anything over and the whole tone of the motor changes and the vibrations set it (while under load). As soon as you lay off the accel... the vibrations go away and the engine sounds normal again.
I guess we will see ??
post #10 of 39 (permalink) Old 05-09-2016, 12:57 PM
sh1520's Avatar
I can't wait to find out what the stealership comes up with! Be sure to let us know
2016 FLTRU
sh1520 is offline
2016 RGS for $48,000 FLTRXS18 *General Road Glide Discussions/Pictures 12 11-02-2015 10:16 AM
no power below 3k rpm engine issues moosedrool Troubleshooting for Road Glides 5 03-08-2015 09:58 AM
How dependable are RG's over 50.000 miles brightonrider *General Road Glide Discussions/Pictures 31 07-16-2014 06:51 AM
1,000 mile trip put me over 20k miles Grapnel *General Road Glide Discussions/Pictures 9 05-19-2013 06:31 PM
$5,000,000.00 Garage Fat Tom General Off-Topic Discussions 11 10-05-2012 09:13 PM
