Weird acceleration issue - Road Glide Forums
post #1 of 18 (permalink) Old 05-08-2016, 02:28 PM Thread Starter
First off I would like to say how thankful i am to have joined the Road Glide community. This is my first H-D and I knew right away this was the model I wanted. I have been riding for over 17 years, but stuck to rockets, and this was the best choice i've ever made.
Now for my issue:
08 Road Glide - 37,000 miles
Today I noticed an issue which all 3 times happened in the same situation. I had come to a stop, began accelerating, then opened it up to feel it out. On all 3 occasions, the bike suddenly stopped wanting to go faster, even with full throttle applied, it was barely revving just enough to barely more. Pulling over, turning off, then restarting solved the problem, but now I want to find the root cause to have it gone. Does this sound familiar to anyone? I could not find anything online because i could not desciribe properly in search haha. Thanks all.
TqAmsNy is offline
post #2 of 18 (permalink) Old 05-08-2016, 03:40 PM
Bleachey's Avatar
So the engine didn't rev, like the clutch was slipping? It doesn't sound like it, just wanting to clarify.
Did you feel any difference in the tension on the throttle?
2011 Road Glide Ultra
Bleachey is offline
post #3 of 18 (permalink) Old 05-08-2016, 03:47 PM
It idles fine? and ya can Rev rpm's, gooses good
reds4 is offline
post #4 of 18 (permalink) Old 05-08-2016, 05:48 PM
Sounds like your bike was in limp mode. When the bike detects a problem, it can go into limp mode. Check for trouble codes. Turning bike off and back on resets limp mode , but it will come back.
post #5 of 18 (permalink) Old 05-08-2016, 06:09 PM
There was a recall/service bulletin issued for 2008 fuel pump/fuel filter housing cracks on touring models. HD fixed the problem on later VIN numbers. They were were replacing the fuel pump housings under the recall. Go to the HD website and plug in your VIN to see if yours is affected.
One test I've heard of : Have the fuel tank 1/8 to 1/4 full....With the ignition off....take off the gas cap....look inside the tank with a flashlight....turn the ignition on and look for fuel spraying in the tank. This could indicate a cracked fuel pump/filter housing.
Just a thought.....PS Don't use a match....LOL
G5Driver is offline
post #6 of 18 (permalink) Old 05-08-2016, 06:40 PM Thread Starter
LOL thakns for the heads up with the match...and thanks everyone for the advice. I will check the H-D website about the recalll....and to answer the first question, tension on the throttle was the same, it was almost like a slipping clutch feel, but i could feel it moving (putting along) just wouldnt' go past like 3k rpms or less
TqAmsNy is offline
post #7 of 18 (permalink) Old 05-08-2016, 07:09 PM Thread Starter
Now that i knew what it was called lol, i checked the codes and came up with both P1511 and P2101, now i'm researching that to see what the steps should be..
TqAmsNy is offline
post #8 of 18 (permalink) Old 05-08-2016, 07:16 PM
Bleachey's Avatar
Those codes are EFI Power Management Mode and Throttle Position Sensor. A quick google search told me it has happened to others and it was related to the ECM. Apparently there was a download that fixed the issue.
Bleachey is offline
post #9 of 18 (permalink) Old 05-08-2016, 07:17 PM
TYM2GLIDE's Avatar
P1511 EFI Power Management Mode
P2101 EFI Motor Circuit Range Performance (Actuation Error)
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #10 of 18 (permalink) Old 05-08-2016, 07:28 PM
Redfish-Joe's Avatar
If memory serves me correctly, the 08 had a problem with the ECM remembering your last throttle position when it was turned off. Sometime resulting in a high idle situation for several start stop cycles. A down load fixed that.
The TPS was also a weak link in 08. I replaces 3 under warranty.
Redfish-Joe is offline
21" wheel vibrates on hard acceleration Afacey *General Road Glide Discussions/Pictures 22 09-24-2015 12:13 PM
High RPM's, no acceleration Desert Dweller Troubleshooting for Road Glides 9 04-17-2015 10:00 PM
Having a weird issue with radio/air ride/controls ??? GrafixxMan Audio 3 06-02-2014 10:04 PM
Lifter Acceleration BlackDangerous Engine Related 13 02-02-2012 09:25 PM
Poor Acceleration 2BWILD Troubleshooting for Road Glides 17 08-19-2010 04:09 PM
