Brake Fluid is a Milky White Color - Road Glide Forums
 3Likes
  • 1 Post By DuraGlide
  • 2 Post By JacktheBagger
post #1 of 10 (permalink) Old 05-10-2016, 07:44 PM Thread Starter
RGKen's Avatar
My neighbor has an 05' Road King and just had to replace his rear tire. After he did he noticed that he kept having to pump up the pressure for the rear brakes every time he used them. He said whenever he gets them pumped up they hold and that they don't leak down as long as he holds his foot on the break. We cannot find any leaks anywhere and he has bleed them and replaced the fluid twice with no luck at solving the issue. The brake fluid starts getting this white milky look to it after he uses it for a while. I think it is getting air in it somehow and the tiny air bubbles are what is giving it that look. Anyone have any ideas what may be going on?
2018 FLTRXS
RGKen is offline
post #2 of 10 (permalink) Old 05-10-2016, 08:08 PM
Time to rebuild the master cylinder. Did he use dot 5 when he bleed the brakes ?
post #3 of 10 (permalink) Old 05-10-2016, 08:25 PM
Harley brakes are a sumbitch to bleed. Buy or borrow a MityVac and vacuum bleed them before you start rebuilding components. Might cure the problem.
RGKen likes this.
DuraGlide is offline
post #4 of 10 (permalink) Old 05-10-2016, 08:47 PM
I would definitely try pressure bleeding them before you rebuild or replace anything. Unless of course the wrong brake fluid or something other than brake fluid was used. If something other than brake fluid was used, say oil then start rebuilding or replacing because the seals and o-rings will deteriorate. I've been a mechanic in the auto industry for most of my life and you'll be amazed how many times people have put motor oil in the master cylinder
post #5 of 10 (permalink) Old 05-10-2016, 08:47 PM
My He said whenever he gets them pumped up they hold and that they don't leak down as long as he holds his foot on the break. ?
So you got peddle? Or do you have to pump it to gain again, still air in then, sounds like not bleeding em right
reds4 is offline
post #6 of 10 (permalink) Old 05-10-2016, 08:52 PM Thread Starter
RGKen's Avatar
He said it pumps up and holds but when he lets off and rides for a while he has to pump all over again.
2018 FLTRXS
RGKen is offline
post #7 of 10 (permalink) Old 05-10-2016, 08:54 PM Thread Starter
RGKen's Avatar
I'll ask him tomorrow which fluid he used to see if that's the issue. He's been around bikes for a while so I did assume he knew what fluid to put in but I will double check.
2018 FLTRXS
RGKen is offline
post #8 of 10 (permalink) Old 05-10-2016, 09:17 PM
There's still air in there, pump up hold down bleed (burp) air close repeat to near full peddle, keeping fluid head pressure right
Use tubing on bleeder?
reds4 is offline
post #9 of 10 (permalink) Old 05-11-2016, 12:32 AM
JacktheBagger's Avatar
milky white is moisture , a rebuild will be in order , as we all know moisture will create rust , brake fluid is very hydroscopic ..
RGKen and reds4 like this.
2011 Ultra
JacktheBagger is offline
post #10 of 10 (permalink) Old 05-11-2016, 05:39 AM Thread Starter
RGKen's Avatar
Yes he used tubing but it was just one of those little economical one person bleeder kits.
2018 FLTRXS
RGKen is offline
Halo mods..anyone used a color besides white? hoosierboarder Lighting 4 07-22-2016 08:58 PM
Inner Fairing painted color other than primary bike color or black? jethro_3 Paint & Bodywork Section 21 09-21-2014 09:39 PM
Milky oil? Stag556 Fluids and Lubricants 14 01-05-2014 01:23 PM
Brake Fluid Leak lldsilver41 Tech Area 2 09-10-2012 02:28 PM
How often do you flush your brake fluid? jcanrun *General Road Glide Discussions/Pictures 12 05-08-2011 01:28 PM
