changes brought changes. - Road Glide Forums
  • 1 Post By pauld
post #1 of 4 (permalink) Old 05-11-2016, 08:56 AM Thread Starter
I recently did some mods to the bike.
These included new clutch cable, and new SE spark plug wires.
I took the tank off to route the plug wire and left the tank off while I worked on the clutch cable. There were a few times when I checked the wires under the tank that lead to many things including the injectors. I move them a little but did not disconnect or pull hard on them.
So, got everything back together and now I have minor hesitation at steady throttle at almost any speed and from 2,000 rpm on up to 3500 rpm. Speeds of 35, 45 and 65.
I do have the SE Pro tuner. I plugged it in and there were no codes.
Perplexed
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #2 of 4 (permalink) Old 05-11-2016, 08:18 PM
Ohiobellboy's Avatar
Didn't pinch the fuel line putting it back together did you?
A.K.A OBB
Ohiobellboy is offline
post #3 of 4 (permalink) Old 05-11-2016, 08:24 PM Thread Starter
SOLVED.
I pulled the plugs tonight. Front cylinder plug gap was small!!! I do not recall dropping it or re-gapping it but somewhere it must have happened.
Put pre gapped plugs i have on hand in...seems ok now. Will know for sure tomorrow.
anonymous_1 likes this.
2018 Road Glide
ABS. Boom Audio
pauld is offline
post #4 of 4 (permalink) Old 05-11-2016, 08:44 PM
Smarty's Avatar
Originally Posted by pauld View Post
solved.
.040
2016 RGS Black Quartz
Smarty is offline
Wheel changes = ride changes eldridgetom Wheels and Tires 3 09-22-2013 11:06 AM
Brought my new 2013 Road Glide home today! bear25314 *General Road Glide Discussions/Pictures 40 02-24-2013 01:50 PM
Brought the new toy home! Govdog76 Road Glide Specific Discussions 16 02-27-2011 07:09 PM
Brought Her Home Today HUTMO *General Road Glide Discussions/Pictures 36 05-07-2010 04:18 PM
brought the 2010 FLTRX home March 30th! Deuce Bigelow *General Road Glide Discussions/Pictures 14 04-12-2010 06:43 PM
