Possible valve train noise - Road Glide Forums
 10Likes
post #1 of 21 (permalink) Old 05-20-2016, 10:55 PM Thread Starter
I'm getting alil ticking sound which sounds like valve train noise in the higher rpm range every once in a while. It's not a hard engine knock but more of a tick. It's not too bad but I happened to notice it tonight on the way home from work. I know there's been people reporting lifters leaking down. It's a bone stock 96" with 45k miles that's never been opened up other than for compensator issues. Is there anything in particular I should look for? Note.. the bike runs great other than the occasional noise
post #2 of 21 (permalink) Old 05-20-2016, 11:35 PM
lil chief's Avatar
It's very possible that at 45k miles, you could use a new set of lifters. I'm assuming you are running the original lifters and they could be getting a little tired by now.
Lil Chief
rlaf75 likes this.
lil chief is offline
post #3 of 21 (permalink) Old 05-21-2016, 06:23 AM
HellInABucket's Avatar
I would just ride the thing and turn up your stereo. These bikes just make a ton of noise and clatter. It used to drive me nuts, but everything's been fine after tens of thousands of miles, I've decided I cant let it bother me anymore.
Harleyagain and bigdoug1130 like this.
HellInABucket is offline
post #4 of 21 (permalink) Old 05-21-2016, 08:09 AM Thread Starter
Normally I agree with you but this noise is brand new within the past 100 or so miles so I want to nip this in the bud before it becomes something more than a slight valve train noise
post #5 of 21 (permalink) Old 05-21-2016, 08:13 AM Thread Starter
Lil Chief
That's what I was thinking. I know there's been some concerns about them failing. I also read a thread about automotive lifters can be swapped instead of "harley" lifters. I'm gonna have to dig that one back up and rifle through it again
post #6 of 21 (permalink) Old 05-21-2016, 08:24 AM
lil chief's Avatar
Honestly, I'd get some s&s standards or the comp cams 850-1 and be one & done with it. There's nothing wrong with the 850-1 lifters, and I think you can get em thru Summit Racing for like $17 each.
Lil Chief
FrankieB and rlaf75 like this.
post #7 of 21 (permalink) Old 05-21-2016, 08:48 AM
RGKen's Avatar
I think most of the concern was with the lifters in the 110"
I don't remember seeing any issues with the 96" engines and their lifters. I know I had 64k on mine when I traded it and it sounded and ran as good as it did when it had 20k on it. Did you by chance change helmets recently maybe due to warmer weather like from a 3/4 or full face to a 1/2? I know when I wear my modular for a while and then switch to a half I think "Holy cow this thing is noisy!" And then after a while I realize it's no louder than it was and it's not even that loud of a noise.
2018 FLTRXS
RGKen is offline
post #8 of 21 (permalink) Old 05-21-2016, 09:08 AM Thread Starter
I get what you're saying but I don't wear a helmet. This is definitely a new noise
RGKen likes this.
post #9 of 21 (permalink) Old 05-21-2016, 09:12 AM Thread Starter
Lil Chief
The way I look at it is if I can put a set of lifters in it won't hurt even if that isn't my problem. I'm not easy on the bike and it owes me nothing. So for a few bucks and a couple hours of my time I'll go with a set of new lifters and see what happens
post #10 of 21 (permalink) Old 05-21-2016, 11:22 AM
Any chevy 350 LS1 lifter will work but you may want to get a mechanics stethoscope (cost $10 to $15) and listen for the source of the noise before assuming it is the lifters, noise has a funny way of traveling and it could be anything such as a loose exhaust baffle for example.
If the lifter bleeds down you will usually hear the ticking when the bike is first started after the engine has been sitting for awhile and the ticking will go away after the lifter pumps back up. If the roller bearing on the lifter is going bad you will hear more of a squeaking noise which usually happens at higher RPM but as the roller get worst it will happen at lower RPM too.
RoadRider likes this.
Compensator or valve train noise???? StGhost Engine Related 19 08-29-2018 09:16 PM
Valve train noise 1st Sgt Engine Related 11 01-15-2018 04:12 PM
Valve train noise thread sfcusaret2004 Engine Related 12 08-29-2016 04:09 AM
Valve intake noise/cam overload noise Budd559 Engine Related 9 02-15-2016 05:23 AM
Increase in Valve train noise when engine cold StriderJim Troubleshooting for Road Glides 8 10-07-2012 09:21 AM
