Bike won't start! - Road Glide Forums
 3Likes
post #1 of 16 (permalink) Old 05-23-2016, 08:32 AM Thread Starter
the88virgnian's Avatar
Unhappy Bike won't start!
13 RGU. I keep the bike hooked up on a battery tender whenever I'm not riding. Went to ride to work today, battery tender (Harley Model) was flashing green, meaning the battery is good to go. So I unhook the tender, turn the bike on...it cranks once and then rapid fire "clickclickclickclickclick". Figured maybe the outlet was bad (have a history of that with this garage), so I changed the outlet the tender was hooked into. Not 5 seconds after hooking it up, the light on the tender starts flashing green again, but this time the bike wouldn't even crank, just "clickclickclickclickclick". When I get home tonight I'll try another charger, see if maybe my tender has crapped the bed? It's a 3 y/o stock battery, though. Might be about that time for a swap?
2013 RGU BBP. Detachable Tour Pack, aftermarket slip ons (no name), Wild 1 WO612s, Avon Cushion Grips, 13" Madstad, Kenwood Excelon x799, 8x DD Speakers (4x VO-M, 2x CXS 6.5, 2x B3), Diamond Micro 4v2 Amp.
the88virgnian is offline
post #2 of 16 (permalink) Old 05-23-2016, 09:09 AM
VikingRider's Avatar
Hi "88", I would recommend getting a multimeter (VOM). Check your battery before discarding it. The mulitmeter is also nice to have checking the battery charging when your engine is running. I have no experience with the MoCo b.t. but I highly recommend the Deltran battery tender (Plus High Efficiency 12v. 5 amp. 4-stage Smart charger).
BlueBagger12, shrknz and sh1520 like this.
FLTRSEI2
VikingRider is offline
post #3 of 16 (permalink) Old 05-23-2016, 09:13 AM
lil chief's Avatar
Check your battery cables. Make sure they are clean & all connections are tight. My old 02 FLHT was infamous for the cables loosening up at the battery.
Lil Chief
lil chief is offline
post #4 of 16 (permalink) Old 05-23-2016, 09:32 AM
Bleachey's Avatar
Good recommendations above. I have heard of batteries showing good, i.e. the green light on the tender, but having a bad cell. 3 years is a good life for a battery.
2011 Road Glide Ultra
Bleachey is offline
post #5 of 16 (permalink) Old 05-23-2016, 09:37 AM
When was the battery replaced in the security fob? That was my problem.
lbarnwell is offline
post #6 of 16 (permalink) Old 05-23-2016, 09:54 AM
PGR
PGR's Avatar
The tender flashing green is not "good to go". Solid green means "good to go". Flashing green is one of three things. It's either "almost" charged, the battery is starting to go south, or you have a bad connection to the battery. My guess is a bad connection. Grab a 10mm wrench and tighten the battery bolts.
Ron..........................
PGR is offline
post #7 of 16 (permalink) Old 05-23-2016, 11:05 AM
My Heritage had a loose ground at the frame ( it was dicked around with by LED guys) and it acted the same way. My Problem was that the battery soon died after the ground was fixed. I bet the tender was just marginally providing amps.
Couple years, maybe three, on a battery here in the desert is pretty good life.
A good tip, if multiple grounds are attached at the frame, then make sure the bolt has a washer to provide a slipping point for the cables so they can stay aligned. Also make sure the bolt is long enough with plenty of turns of thread engagement.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #8 of 16 (permalink) Old 05-23-2016, 11:20 AM
another vote for a loose ground, it happened a few times on my last ultra, same symptoms.
2013 RGU, black of course....
y2kflhr is offline
post #9 of 16 (permalink) Old 05-23-2016, 08:01 PM Thread Starter
Got home and hooked it up to a proper charger. Got it up to 100 percent. I'll double check the battery terminals for tightness, and hook it back up to the tender. Are there other ground locations I should be aware of, besides where I grounded my amp (inside the fairing)?
post #10 of 16 (permalink) Old 05-23-2016, 08:26 PM
The battery terminals are notorious for coming loose
y2kflhr is offline
Bike won't start!! Slammed Troubleshooting for Road Glides 7 09-19-2013 09:02 PM
Added lights - now bike won't start Red Dawg Troubleshooting for Road Glides 10 08-19-2013 07:45 PM
bike won't start Onthehunt49 Troubleshooting for Road Glides 7 06-22-2013 11:47 AM
Need help Bike won't start cwdouble Road Glide Specific Discussions 10 02-20-2012 11:07 AM
bike won't start briscoe *General Road Glide Discussions/Pictures 11 11-28-2010 10:25 AM
