Unusual sound - Road Glide Forums
post #1 of 4 (permalink) Old 12-27-2012, 02:36 PM Thread Starter
justincollins's Avatar
Unusual sound
After installing new brake pads I have noticed some squeaking as the from wheel rolls. It only squeaks as it toucks the rotor on the exact same point every time around. Does anyone have any suggestions or have ever had this problem.
2009 Red Hot Sunglo Glide
Stage 1
Cobra Slip-ons
justincollins is offline
post #2 of 4 (permalink) Old 12-27-2012, 03:02 PM
Did you install ceramic pads? If so, they can squeak.
I haven't installed pads on my bike, but when I do my car and truck! I use CRC anti squeal between the calipers and pads.
Also, if you got any grease on the rotor, that will cause a squealing noise. If you think that's the problem, clean your rotors with Brake Clean or some type of brake cleaner.
I am assuming your bearings are OK.
Captain13 is offline
post #3 of 4 (permalink) Old 12-27-2012, 07:15 PM Thread Starter
Yea my bearings are fine its nothing big just noticable at slow speeds. They were cheaper pads from china, so that may be the problem. Ill try brake cleaner tho. THanks
Stage 1
Cobra Slip-ons
post #4 of 4 (permalink) Old 12-27-2012, 07:28 PM
Triplej's Avatar
Sounds like you may have a brake rotor slightly warped. If you do not feel any vibration under braking, other than the noise being a nuisance I would not worry about it to much.
There is a procedure for cleaning your caliper pistons shown on the Lyndall website. Sometimes this will help as it allows the piston to fully retract back into the caliper keeping the pads from rubbing on the rotor. Might be worth a try.
Triplej is offline
Unusual Road Noise KansasFLTRU Tech Area 10 05-18-2018 12:54 PM
Unusual wear on Michelin Comm II mjsdouble Wheels and Tires 28 05-05-2015 02:21 PM
An unusual framed pic of a RGC mjsdouble *General Road Glide Discussions/Pictures 28 08-12-2013 02:59 PM
Unusual green bike HOGCOVERS Hogcovers, LLC 2 07-20-2012 07:21 PM
