Small moisture around Centering Screw on Tranny - Road Glide Forums
post #1 of 3 (permalink) Old 05-23-2016, 09:06 PM Thread Starter
Good Day, I have a 2015 Road Glide Special. I curently only has 4K miles on her. I noticed today she as slight moisture around "Centering Screw" on right side of Tranny. The bike is under warranty so no issues there. Just curious to why it could and would leak. I seen older bikes have the issue but figured Harley would fix it. Also I'm using Amsoil 15w-140. Shifts great and no issues. I've attached a pic and just would like some insite.
DocHoliday1934 is offline
post #2 of 3 (permalink) Old 05-24-2016, 10:01 AM
Hard to tell by the pic, but I think it looks like oil seepage. Good thing to keep an eye on in case the transmission oil pan is a poorly manufactured unit. If the metal is too porous it may accumulate and eventually drip. Safety issue?? Definitely messy.
grambo is offline
post #3 of 3 (permalink) Old 06-02-2016, 10:15 AM Thread Starter
UPDATE:
I figured the "wetness" came after using 75W-140 Amsoil Gear oil with 2000 miles since change that I should change it. I ordered some Amsoil Tranny Fluid which I believe is a lighter weight gear oil since it smells the same (Horrible). I took 50/50 water and simple green and sprayed and cleaned the area twice as to remove all residue and since doing the changes I haven't seen the wetness come back.
HELP?? Tranny bolts loosened up after long ride home!! Ma$$hole *General Road Glide Discussions/Pictures 19 07-30-2015 10:33 AM
Small rubber molding around fairing jacksonfdny *General Road Glide Discussions/Pictures 11 08-21-2012 01:21 AM
Tranny bearing causing clutch slippage NoBull Road Glide Specific Discussions 9 12-01-2011 04:06 PM
The dreaded loose tranny bolts PGR Intake and Exhaust 4 10-18-2011 08:35 AM
Painting motor and tranny GordonC Engine Related 2 04-22-2011 04:58 PM
