2005 Stumbling - Road Glide Forums
post #1 of 34 (permalink) Old 10-17-2010, 09:14 PM Thread Starter
Nino's Avatar
2005 Stumbling
I was on my way up to Daytona when suddenly, she begins to stumble on me. It feels almost like it shuts off for a fraction of a second. I took it to a dealer in Daytona and the problem as usual did not replicate itself. It went away for awhile and on my way back home, it did it again. No codes, no check engine light...NOTHING... but it is STILL DOING IT! HELP!!!
Living too large to live too little.
2006 SUZ M109R
2005 SUZ BOULEVARD M50
1995 SUZ KATANA 600
1988 SUZ GS550e
1980 KAW KE350
1975 YAM YZ250
1975 CANAM 250
1975 HON XR75
Nino is offline
post #2 of 34 (permalink) Old 10-18-2010, 11:25 AM
joke's Avatar
In this months American Iron mag guy had the same problem on his 08 - the editor didn't think it was the throttle because that would set a code in the ECM but might be a problem with the wiring to the kill switch. Saying a loose connection would make the ECM think the switch was turned off. No fault code would be triggered. Check the wiring and the voltage drop across the kill switch. Also said that if you are running a Power Commander it might be bad since they over heat and break down. There's a separate fix for that if you have a PC let me know.
2009 Mirage Orange
joke is offline
post #3 of 34 (permalink) Old 10-18-2010, 10:54 PM Thread Starter
Nino's Avatar
Thanx for the quick reply. I'll check the wiring out since I know it got hacked up for installation of my apes.
2006 SUZ M109R
1995 SUZ KATANA 600
1988 SUZ GS550e
1980 KAW KE350
1975 YAM YZ250
1975 CANAM 250
1975 HON XR75
Nino is offline
post #4 of 34 (permalink) Old 10-20-2010, 08:55 PM Thread Starter
Nino's Avatar
I brought the bike into my local shop. The shop comes with very high recomendations due to their fabrications for dragsters. Anyways... I was informed that my ECU was just reflashed and that I never had a EFM installed. He suggested to install a power commander and that would solve the problem. All wiring was OK. Although, I still have to fork-out 700 bills for all the parts and labour. What do you think?
2006 SUZ M109R
1995 SUZ KATANA 600
1988 SUZ GS550e
1980 KAW KE350
1975 YAM YZ250
1975 CANAM 250
1975 HON XR75
Nino is offline
post #5 of 34 (permalink) Old 10-20-2010, 10:23 PM
Rowdy's Avatar
Parts and labor for what? What they have done so far, or for the solution they offered, i.e. EFM and install?
Many of of the EFM's are plug and play, so not sure if ya need to pay a bunch of labor $$$'s for the install. That depends on your wrenching abilities... I am not a wrench at all, so I won't say, it's easy. I haven't gone down this road myself--yet!
Rowdy
Rowdy is offline
post #6 of 34 (permalink) Old 10-21-2010, 10:38 AM
joke's Avatar
A)Well, a new PCV w/AT is about $7 bills - labor would be about 30 minutes unless they also dyno-tune your ride - then $7 bills would be about par. I don't understand the part about not having an EFM installed - unless you did a bunch of upgrades (pipes and air) you shouldn't need an EFM.
B)If you had your ECM (ECU) flashed because you did upgrades - that should have been enough. I just think your indy is trying to get $700 out of you.
C)If you really do need an EFM you can do it yourself and buy one cheaper from eBay or whatever.
D) None of the above.
2009 Mirage Orange
joke is offline
post #7 of 34 (permalink) Old 10-21-2010, 09:05 PM Thread Starter
Nino's Avatar
When my engine blew-up with the stage 3 kit the dealer for warranty purposes bust me down to a stage 2 with an ECM reflash. Since the stumbling, my indie guy recommended I install a EFM and dyno-tune due to it being the right way. I hope I'm doing the right thing?
2006 SUZ M109R
1995 SUZ KATANA 600
1988 SUZ GS550e
1980 KAW KE350
1975 YAM YZ250
1975 CANAM 250
1975 HON XR75
Nino is offline
post #8 of 34 (permalink) Old 10-22-2010, 10:02 AM
joke's Avatar
Absolutely...if you want it done right to get the most hp/tq out of your engine then an EFM and dyno-tuning are the ticket (if done properly) - ONLY IF - you have done a lot of work to your engine, ie, cams, new jugs, & stage II A/C & exhaust. HOWEVER, if you only have the stage II A/C and exhaust you should/will be able to install the PC III or PCV with the supplied parameters, usually on a CD, for your bike's modifications yourself. I ain't no wrench either but I did the V&H FuelPak with no problem at all. You can pick up a PCIII for less than $300. Here's one on eBay for $127 - http://cgi.ebay.com/ebaymotors/Dynoj...Q5fAccessories
Feel the pride of doing it yourself...go for it!
2009 Mirage Orange
joke is offline
post #9 of 34 (permalink) Old 10-23-2010, 09:31 AM Thread Starter
Nino's Avatar
I like that idea! But what if I have the jugs changed from an 88 to a 95 stroker. Can I still use the PCIII? I remember that they had changed the jugs and cams on it when the engine blew.
2006 SUZ M109R
1995 SUZ KATANA 600
1988 SUZ GS550e
1980 KAW KE350
1975 YAM YZ250
1975 CANAM 250
1975 HON XR75
Nino is offline
post #10 of 34 (permalink) Old 10-23-2010, 11:34 AM
Old Harley Guy's Avatar
You can still use the same PCIII. Just re-dyno it at a shop with certified dyno techs. Also, any time I see a stumbling problem like you described, I check the wires at the battery. They can get just a little loose and make all sort of weird things happen.
Good Luck
2005 Road Glide
117" with Baker DD6
+1 oil pan
Alloy Art Stabilizer
Custom Candy paint
D&D Borzilla
Old Harley Guy is offline
Engine stumbling from idle... trainz71 ECM/Fuel Management systems 5 11-22-2017 10:23 PM
2005 Road Glide EFI rlowride ECM/Fuel Management systems 12 08-24-2015 10:11 PM
08 Steady Speed Stumbling FLTRick Troubleshooting for Road Glides 6 07-11-2014 10:30 AM
2005 Black Pearl Road Glide KrackHouse Classifieds Archive (3 months old+) 13 12-28-2010 11:58 AM
WTB silver faced temp gauge for 2005 Effenglide Classifieds Archive (3 months old+) 0 09-20-2010 10:51 PM
