Humming noise during curves - Road Glide Forums
 19Likes
post #1 of 38 (permalink) Old 05-29-2016, 12:24 PM Thread Starter
! rock103 !'s Avatar
Yesterday I noticed a humming noise while in curves. Think it may be wheel bearings? Front bearings are new, so would indicate rear bearings going I guess
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #2 of 38 (permalink) Old 05-29-2016, 12:42 PM
chromedome's Avatar
probably just the less worn tread on the sides of your tires,
no big deal.
mouser58 likes this.
2012 Road Glide Ultra (SOLD) & 2015 BMW R1200RT
chromedome is offline
post #3 of 38 (permalink) Old 05-29-2016, 12:48 PM
Headrope's Avatar
Are wheel bearings an issue on these bikes? I notice something similar on my new-to-me 2010. Slight noise and teensy bit of feel in the handlebars. It has 15,000 miles on it but was completely gone through by a dealership so I just figured I leaned further in turns than the previous Owner?
Headrope is offline
post #4 of 38 (permalink) Old 05-29-2016, 01:34 PM
Tires are cupped - mine started doing it around 8k miles
tOSUSteve is offline
post #5 of 38 (permalink) Old 05-29-2016, 01:55 PM
Dunlop tires? My new rear Dunflop is cupping already. Look at the tread that curves up the sidewall. If it looks like the teeth on a saw blade, that's most likely the issue.
RGKen, BlueBagger12 and JGray like this.
DuraGlide is offline
post #6 of 38 (permalink) Old 05-29-2016, 02:31 PM Thread Starter
A buddy had his cupped OEM tire replaced under warranty at my local dealer. Think I will check that out and see if I can get a new tire out of them. Seems to be developing a noise vibration on parking lot speed turns as well.
post #7 of 38 (permalink) Old 05-29-2016, 04:00 PM
r_einan's Avatar
I'm hearing the same thing and seeing visible signs of cupping on the front starting at about 10k. Pressures are checked and maintained regularly. Makes me wonder about dunlops QC. I'm at 11k now and I can start to feel the cupping on the corners. Probably have to have my parts gal (my wife, lol) order me up a metzler 888 here in a couple weeks.
r_einan is offline
post #8 of 38 (permalink) Old 05-29-2016, 04:34 PM
The stock Dunlops are notorious for cupping. Mine does the same thing around corners while leaning.
post #9 of 38 (permalink) Old 05-29-2016, 04:39 PM
Q-Hog's Avatar
Similar noise here as well, but I did have to replace my front wheel bearing. But that was a different sound and feeling all together.
Q-Hog is offline
post #10 of 38 (permalink) Old 05-29-2016, 04:52 PM
sj01fltri's Avatar
My 12 did the same thing more so on left hand turns
sj01fltri is offline
Humming sound Rglide16 *General Road Glide Discussions/Pictures 5 08-13-2016 03:12 PM
Front and rear humming noise Cory Troubleshooting for Road Glides 6 07-27-2014 12:41 AM
Front end "humming" when turning left yzhammer Troubleshooting for Road Glides 16 05-30-2014 10:32 AM
Buzzing/Humming noise under light load TheDon81 Troubleshooting for Road Glides 1 05-08-2012 12:17 PM
Gyration on curves BDMastiff *General Road Glide Discussions/Pictures 24 01-18-2011 11:37 AM
