Cold Temp. Tach & Speedo fail ??? - Road Glide Forums
post #1 of 6 (permalink) Old 10-18-2010, 09:18 PM
Florida Cracker
Guest
Posts: n/a
I am from Florida so by cold I mean below 60deg.F. Started the end of last winter, tach and speedo jump all around then fall dead repeatedly from start up until temp gets above 60 deg. as long as 2 hrs.Spent $400 last winter to replace the little box that the codes said was bad ,it lasted about a week and did the same thing Everythig else works fine when this happens just no tach or speedo. Any ideas? Thanks for looking.
post #2 of 6 (permalink) Old 10-18-2010, 09:28 PM
You asked
DON'T Look Down, I'm sorry man, I just had to be a wise @$$
Really do hope ya find out.https://www.roadglide.org/images/styl...or/menupop.gif
Frodoe is offline
post #3 of 6 (permalink) Old 10-19-2010, 07:08 AM
HD-DOC's Avatar
The tach and speedo get there signal from two differant sources, you have to look for a bad ground as they share a common ground. Doc Start under the dash with the speedo and tach.
HD-DOC is offline
post #4 of 6 (permalink) Old 10-19-2010, 07:19 AM
pte359's Avatar
Not had a problem with my tach but on real cold morning my speedo will peg out at 120 for several miles and then it wil settle down to correct speed. mine is a 99 so it is cable drive off the front wheel.
PROUD USAF Dad.....
pte359 is offline
post #5 of 6 (permalink) Old 10-19-2010, 12:19 PM
Redfish-Joe's Avatar
Never had trouble with the tach but on my west coast trip my speedo would quit working after about 5 miles in the higher, cooler temps and in the dessert it would not work from the start. Both cases it would start back working. I had the VSS replaced when I got home and it is doing ok .
Redfish-Joe is offline
post #6 of 6 (permalink) Old 10-19-2010, 05:22 PM
Florida Cracker
Guest
Posts: n/a
Thanks to all.
Speedo/Tach connector & pins??? Papi63 *General Road Glide Discussions/Pictures 0 12-24-2013 01:41 PM
speedo and tach fail LegacyVet Troubleshooting for Road Glides 6 10-28-2013 03:22 PM
Speedo & Tach bulbs jimmyray11349 *General Road Glide Discussions/Pictures 1 08-09-2011 07:54 AM
Silver Faced Speedo & Tach rmack888 Classifieds Archive (3 months old+) 0 02-22-2011 05:04 PM
Dallas area Speedo & Tach LED's Hyde Classifieds Archive (3 months old+) 6 10-09-2010 08:59 PM
