Trouble Code 0572 - Road Glide Forums
post #1 of 12 (permalink) Old 06-05-2016, 07:55 AM Thread Starter
Q-Hog's Avatar
Trouble Code 0572
Need some help figuring out a problem on my 12 RG. My accessories fuse keep popping.. when it pops, the turn signals, brake lights don't work and cruise control light won't switch on when pressed. Also I have a trouble code of 0572 which is the rear brake switch. Thx.
Q-Hog is offline
post #2 of 12 (permalink) Old 06-05-2016, 09:03 AM
My guess is the cruise control does not work due to the code. My experience is that the cruise is disabled when there is something wrong.
The lights, I have no idea. sounds like it is time to take it in and have it looked at. Have you cleared the code, to see if it comes back again?
Diverrick is offline
post #3 of 12 (permalink) Old 06-05-2016, 09:16 AM
Did you unplug the rear brake light switch and see if the fuse holds? It may be a good place to start, if the the fuse pops with the brake switch unplugged then use a multimeter to check if there is a short in the plug or wires.
post #4 of 12 (permalink) Old 06-05-2016, 10:30 AM Thread Starter
Q-Hog's Avatar
I haven't troubleshoot it too far. I just checked the wires along the frame to see if any were pinched. I found none. I'll take your advise and try unplugging the brake switch. But I confused when the blown accessories fuse would cause brake light and turn signal inoperable. Thx.
Q-Hog is offline
post #5 of 12 (permalink) Old 06-05-2016, 11:46 AM
Smokey's Avatar
Sounds like the brake switch itself may be shorting out. Besides the brake lights and turn signals not working, the cruise control will also be disabled if this switch is bad. You need to confirm it's the back brake switch and not the front although the code indicates the back. Put a new fuse in and pull the front brake. If the fuse doesn't blow then try the back brake. When you find out which circuit (front or back) is blowing the fuse test that switch. If the switch is good then start tracking the wires in that circuit (front or back) starting at the switch.
Smokey is offline
post #6 of 12 (permalink) Old 06-05-2016, 12:56 PM Thread Starter
Q-Hog's Avatar
Good info. The fuse pop as soon as I insert it.
Q-Hog is offline
post #7 of 12 (permalink) Old 06-05-2016, 02:06 PM Thread Starter
Q-Hog's Avatar
Smarty, also I while the fuse is blown I have no rear running light and front turn signals as well. But the head light and high beams work.
Q-Hog is offline
post #8 of 12 (permalink) Old 06-06-2016, 08:30 AM
If the fuse blows as soon as you put it in then there is a direct short somewhere.
Did the fuse blow when you turned on the ignition or did it blow when the ignition is off.
If the fuse blew with the ignition off then the short may be in a feature that stays on all the time such as the security system.
post #9 of 12 (permalink) Old 06-06-2016, 08:41 AM Thread Starter
Q-Hog's Avatar
It only blows when the ignition is turned on. Very strange. I have not don't anything to the bike in several month and now for this to happen. I don't really know where to start to check for a bad wire.
Q-Hog is offline
post #10 of 12 (permalink) Old 06-06-2016, 08:49 AM Thread Starter
Q-Hog's Avatar
It only blows when the ignition is turned on. Very strange. I have not done anything to the bike in several months and now for this to happen. I don't really know where to start to check for a bad wire.
Q-Hog is offline
Error code question or at least I think it's an error code wvdave Troubleshooting for Road Glides 1 07-15-2015 10:21 AM
Need help. On the road trouble code P0118 DC-3Mek ECM/Fuel Management systems 21 08-20-2013 05:53 PM
Hydraulic Clutch throwing trouble code 69 A-body Controls & Handlebars 3 08-29-2011 08:10 PM
New bars on...getting a trouble code BigDum Controls & Handlebars 6 08-19-2011 12:03 AM
Signature Pic Trouble Rottiman *General Road Glide Discussions/Pictures 5 06-28-2010 11:50 AM
