ebc brakes double h sintered? do you like them ? - Road Glide Forums
 8Likes
post #1 of 18 (permalink) Old 06-15-2016, 07:54 PM Thread Starter
4,500 on the rear and they are the noisiest piece of shits . ran the stock ones .replaced at 10 k and 20k . decided to save a few dollars and bought 4 sets. I changed the front and rear both at 20k and the rear sound like they are metal on metal. so I pulled them and inspected them. they look like the other unused ones I have.
maybe a bad set?
I think I will trash this set and put another on as I have them.
just curious if any others have the same complaint.
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #2 of 18 (permalink) Old 06-15-2016, 08:03 PM
maybe a bad set?
Are you cleaning the calipers up real good when changing pads ? If they don't slide off the rotor they're going to make noise. Also , use brake quiet on the back of the pads to helps reduce noise.
RGKen likes this.
post #3 of 18 (permalink) Old 06-15-2016, 08:16 PM Thread Starter
when I took them off to inspect them I did dab on some of that brake goop on them. I have the bike on the jack now and bags off as I am cleaning the wheels so tomorrow night I will change the pads and hope for the best.its only 5 minutes but I hate throwing money away.
2011 RG ULTRA.
CPY84 is offline
post #4 of 18 (permalink) Old 06-15-2016, 08:17 PM
'05Train's Avatar
Clean the calipers and the pistons well. I grease the pins in the calipers, and I use that red monkey snot ant-squeak stuff on the back of the pads. I love the EBC HH Sintered pads. Not a lot of dust and they really bite well.
Redfish-Joe likes this.
'05Train is online now
post #5 of 18 (permalink) Old 06-15-2016, 11:03 PM
rideon's Avatar
Had the ebc's, squealed like crazy, went back to the over priced Harley pads.
2018 Road Glide Special, vivid black
rideon is offline
post #6 of 18 (permalink) Old 06-15-2016, 11:12 PM
! rock103 !'s Avatar
I have a set of EBC semi sintered on the shelf that I'm gonna install when I get back home. Plan to anti squeek grease the back of the pads and pins
USMC 1990-2000 (0311/6017)
! rock103 ! is offline
post #7 of 18 (permalink) Old 06-16-2016, 06:59 PM Thread Starter
just took them apart again. cleaned them. greased them .
put them back on. its raining. try it tomorrow. if they make noise again, oem go back on.
2011 RG ULTRA.
CPY84 is offline
post #8 of 18 (permalink) Old 06-17-2016, 09:49 AM
I use Permatex synthetic disc brake lube on the back of the disc brake pads and that eliminates the squeaking.
RGKen likes this.
post #9 of 18 (permalink) Old 06-17-2016, 02:26 PM
I've been using $7 D2Moto sintered pads with zero issues. I was very skeptical about them at first because I thought how can $7 brake pads be good! I like them so much I bought 9 sets of them because they always run out of stock. I also use a brake silicone on the back of the pads and caliper pins, basically anywhere the pads touch the calipers I will apply a very thin coating of the silicone. Just don't get any on the pad surface or the rotor. They stop the same as stock pads and have WAY much less brake dust. Oh and no noise either
post #10 of 18 (permalink) Old 06-18-2016, 10:16 AM
Ralf you are a disc brake pad HOG! No wonder I can't get the D2moto brake pads anymore.
Big_gary, rlaf75 and RGKen like this.
Which do you use more? Front Brakes or Back? turbochrisb *General Road Glide Discussions/Pictures 41 09-18-2017 11:38 AM
SWVII Raffle Sponsor EBC BRAKES TracyB ARCHIVES-SWVII Cherokee 2 05-23-2017 05:24 PM
Brakes: Kevlar VS. Sintered/ceramic mouser58 Safety Area 2 01-05-2015 05:21 PM
After you install J&M or other speakers, what do you do with the factory speakers? Black09inOK Do-IT-Yourself 6 10-01-2010 01:53 AM
