No front brake? - Road Glide Forums
post #1 of 7 (permalink) Old 06-16-2016, 07:16 AM Thread Starter
Shadow Reaper's Avatar
No front brake?
ok this i never encountered before.
changed handle bars, had some pinched wires and sorted that problem out, test drove about 30 min everything fine.
on the way to work this morning (10 min ride) the check engine light comes on and i have no front brakes, lever pulls like there is no brake fluid, abs light was not on.
get to work and there is no leaks, and when i turned the bike back on brakes were back, any ideas?
Four wheels move the body. Two wheels move the soul.
Shadow Reaper is offline
post #2 of 7 (permalink) Old 06-16-2016, 09:43 AM
Did you replace brake lines when you did the bars? Make sure everything in the control is there and nothing got bent or fell out at the lever and master cylinder
post #3 of 7 (permalink) Old 06-16-2016, 10:42 AM Thread Starter
didnt replace brake lines, not sure if anything fell out, its weird, i had brake then no brakes then brakes again, i dont get it
post #4 of 7 (permalink) Old 06-17-2016, 09:12 AM
TLKurtz's Avatar
Send a message via Skype™ to TLKurtz
What year bike? Not certain on this, but I thought that was a recall issue for some bikes.
-TLKurtz (Mr. Wizard) - Blackhorse Cavalry Nomads VMG member (2/11 CAV - East/West German Border)
2015 RGS - Vivid Black and loads of fun.
Reside in Vegas. I keep cold beer in the fridge for all visitors.
TLKurtz is offline
post #5 of 7 (permalink) Old 06-17-2016, 09:35 AM
you need to get the air out of the lines, needs to be done a couple of times
preacher is offline
post #6 of 7 (permalink) Old 06-17-2016, 01:06 PM Thread Starter
2013 road glide ultra
post #7 of 7 (permalink) Old 06-17-2016, 01:51 PM
VikingRider's Avatar
I'm not a mechanic but I believe it has something to do with the ABS-sensor module. A H-D tech will hook up the diagnostic while servicing the brakes.
Check the DTC-codes; a C-code indicates an issue with the ABS-system (from your recent handiwork ). A work-around to your problem is as simple as just pushing the brake lever 6-8 times (ingnition ON, duh) as this will usually reset the ABS-sensor (flushing the system).
FLTRSEI2
VikingRider is offline
No tail light or front brake light hummbusa Troubleshooting for Road Glides 3 06-23-2015 11:00 AM
Changed front tire now no front brake??? jrbean1 Troubleshooting for Road Glides 9 07-24-2014 10:05 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 02:14 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 05:02 PM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 09:13 PM
