Clutch slipping - Road Glide Forums
 2Likes
  • 1 Post By HeatWave
  • 1 Post By RGKen
post #1 of 8 (permalink) Old 06-18-2016, 09:02 AM Thread Starter
Clutch slipping
I have a 2015 road glide with 2000mi and I changed my primary and trans fluids and replaced both with formula 1 primary and trans fluid. Now my clutch is slipping any reason why?
Jnau2015 is offline
post #2 of 8 (permalink) Old 06-18-2016, 05:22 PM
I would pull the derby covery and adjust the clutch to be sure that is fine. Or use the warranty it still has and take it to your dealer and let them worry about it
post #3 of 8 (permalink) Old 06-18-2016, 07:56 PM
BDMastiff's Avatar
You need to adjust your clutch pack. It's easy. Here's a link to a How To video
https://www.youtube.com/watch?v=Zl92wwLiNwE
1996 Fatboy
BDMastiff is offline
post #4 of 8 (permalink) Old 06-18-2016, 07:56 PM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
I'm with rlaf75, readjust your clutch and try it again. Otherwise you might need to replace the primary fluid.
GOOD LUCK!
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
post #5 of 8 (permalink) Old 06-19-2016, 08:27 AM
Was it slipping before you worked on your bike ? If no, rechecked your work. Did you add too much primary oil ?
post #6 of 8 (permalink) Old 06-19-2016, 09:57 PM
get rid of the pussified stock clutch diaphragm spring and get the screamin eagle one. Several years back (06? 07???) HD made the clutch "easier" to pull by reducing the spring pressure. Any time you go stage one (or even just a better tune), often the soft clutch spring will allow slippage.
I know you said you only changed fluids so imho its likely an adjustment issue as others have mentioned. I just hate the stock springs.
HoustonUltra is offline
post #7 of 8 (permalink) Old 06-20-2016, 11:23 AM
Doesn't the 15 have a hydraulic clutch?
Didn't Harley have recalls on that clutch too? ?
I would take it to the dealer
RGKen likes this.
HeatWave is offline
post #8 of 8 (permalink) Old 06-20-2016, 12:18 PM
RGKen's Avatar
+1^^^^
Take it back to the dealer because you can't adjust a hydraulic clutch anyway so let them sort it out. Probably is the recall that has not been performed on your bike yet.
Smarty likes this.
2018 FLTRXS
RGKen is offline
Slipping clutch craigp95 Engine Related 19 02-18-2016 05:45 PM
Hydraulic Clutch Slipping phillyrube Troubleshooting for Road Glides 3 05-05-2013 03:53 PM
2011 RGU Clutch Slipping brhodea *General Road Glide Discussions/Pictures 12 03-29-2013 01:28 PM
Clutch Slipping? PhrogFlyer Troubleshooting for Road Glides 17 03-11-2013 05:12 PM
stock 103 possible smoked clutch/slipping trans OuchMMC Engine Related 23 10-13-2012 09:29 PM
