Ignition switch Stuck & i mean stuck.... - Road Glide Forums
 7Likes
post #1 of 12 (permalink) Old 06-29-2016, 01:49 PM Thread Starter
maddmoe's Avatar
....ok so someone called me yesterday and said his ignition switch came up & he pressed it back down and when he turned on his bike nothing happened, so i get there and try to remove the ignition switch by depressing the tab at the bottom while turning the key counter clockwise locking the tab in place and this thing WILL NOT COME OUT FOR NOTHING, now i had this issue b4 on another bike but it came out and i was able to line up the ignition with my master key and reinsert the ignition and no problems BUT this one here as you can see , i broke it down into as many pieces as i can and still no luck, any suggestions and or help
Dont talk about it, Be about it !!!
maddmoe is offline
post #2 of 12 (permalink) Old 06-30-2016, 09:50 PM Thread Starter
maddmoe's Avatar
well after removing all the springs and pins we finally got the ignition rod out BUT it seem when the owner shoved it back down it messed something up to the point of him having to drive to Conn. to the only Harley dealer that had what he needed & once i got the part the ignition switch went right in and locked in and started the bike right up and also locked the handle bars like it should..........Moral of the story is if you mess with your ignition switch and it some how pops out you better make sure everything is lined up before you start pounding things back in
item # 20
maddmoe is offline
post #3 of 12 (permalink) Old 07-01-2016, 09:36 AM
HD -Hundred Dollars....
sometimes using a hammer is uncalled for!
2013 RGU, black of course....
y2kflhr is offline
post #4 of 12 (permalink) Old 07-01-2016, 09:12 PM Thread Starter
maddmoe's Avatar
when i first arrived i asked him " How much force did you use" and i got that look a puppy gives you when he knows he wasnt supposed to play with your slippers
chromedome, kouack and RFG7680 like this.
maddmoe is offline
post #5 of 12 (permalink) Old 07-05-2016, 08:39 AM
oh my puppy gives me that look waaaay too often
maddmoe likes this.
y2kflhr is offline
post #6 of 12 (permalink) Old 07-05-2016, 03:46 PM
9over's Avatar
That dam ignition switch really sucks. I get the shakes whenever I have to take it out cause I know it ain't going back in as easy as it came out. You'd think on a 20+thousand dollar machine they'd give you a switch that's easier to work with.
maddmoe and KevDillow like this.
9over is offline
post #7 of 12 (permalink) Old 07-05-2016, 07:05 PM
Ohiobellboy's Avatar
What is this ignition switch thing you speak of? Mine only says fork lock on it.
BobRG15 likes this.
A.K.A OBB
Ohiobellboy is offline
post #8 of 12 (permalink) Old 07-06-2016, 10:42 PM Thread Starter
maddmoe's Avatar
which bike might be yours.......
maddmoe is offline
post #9 of 12 (permalink) Old 07-07-2016, 05:04 AM
'15cvorgu.There's no ignition switch on it, just the fork lock there. Was just having some fun in the thread since you got it fixed.
A.K.A OBB
post #10 of 12 (permalink) Old 07-07-2016, 08:50 AM
bucketlisthd's Avatar
There's no longer a need to remove the ignition switch on the Rushmore RGs. Pop off the chrome horseshoe trim under the switch, and there's enough room to snake everything off with the switch intact.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is online now
Help! Key knob stuck in ignition switch! double Troubleshooting for Road Glides 8 04-15-2016 09:38 AM
Help removing ignition switch. Switch seems stuck? Driftah Controls & Handlebars 5 11-04-2015 07:18 AM
Ignition Switch Stuck tlottman *General Road Glide Discussions/Pictures 4 04-08-2015 02:25 PM
Pro One Smooth Black Billet Ignition Switch Cover 93-06 FLHT & FLTR longrides Parts for Sale 4 11-26-2014 11:58 AM
Stuck brake light switch? Sethjamto *General Road Glide Discussions/Pictures 7 08-21-2012 04:30 AM
