Stripped screw - Road Glide Forums
post #1 of 14 (permalink) Old 10-21-2010, 11:14 PM Thread Starter
Stripped screw
Can anyone tell me an easy way to get a stripped screw out of a chrome front fork bolt cover? I got the chrome piece off of the bottom of the fork but the screw is stripped and I cant get it out of the hole, thanks for any help.... I feel like an idiot
METIME is offline
post #2 of 14 (permalink) Old 10-21-2010, 11:25 PM
NakedSnowman's Avatar
Depending on how much is exposed, you might try some needle nose pliers or needle nose vise grips and grab it and tilt at an angle to hopefully press the screw against the walls of it's location enough to spin out.
NakedSnowman is offline
post #3 of 14 (permalink) Old 10-22-2010, 07:54 AM
If the head of the screw is exposed you can cut a slot in it with a hacksaw or a dremel cut off wheel and use a screwdriver in the slot you just cut to get the screw out.
Halecky Knives is offline
post #4 of 14 (permalink) Old 10-22-2010, 08:24 AM
Bluzmn59's Avatar
I am going to remember that trick, for sure.
Life is hard. It's really hard if you're stupid.
1959 FLHF
2007 FLSTSC
2011 FLTRU
Bluzmn59 is offline
post #5 of 14 (permalink) Old 10-22-2010, 01:19 PM
Redfish-Joe's Avatar
Post a pic so we can see what you are dealing with.
Redfish-Joe is offline
post #6 of 14 (permalink) Old 10-22-2010, 02:58 PM
BDMastiff's Avatar
I'd use my dremel motor to cut a slot in the screw that will fit a flat head screwdriver. Then, just unscrew it.
1996 Fatboy
BDMastiff is offline
post #7 of 14 (permalink) Old 10-22-2010, 04:33 PM
blacktopr's Avatar
I agree with the other solutions but it it is broken off below the surface drill it with a sharp drill and use a easy out (they do make them small enough )
PS
How did you break it off ?
Blacktopr
blacktopr is offline
post #8 of 14 (permalink) Old 10-22-2010, 04:41 PM
blacktopr's Avatar
I had a simile problem in the past .Harley uses some mediocre hardware .I have replaced most of mine with stainless steel .
http://www.gardner-westcott.com/
Blacktopr
post #9 of 14 (permalink) Old 10-22-2010, 05:51 PM
you can also drill a hole and use an easyout!!
2bagger is offline
post #10 of 14 (permalink) Old 10-22-2010, 09:58 PM
Neano62's Avatar
Are you talkn bout the axle bolt? We all gotta learn man! Dont BE an Idiot. lol
[/IMG]
Neano62 is offline
Stripped Inner Fairing Screw Hole the88virgnian Do-IT-Yourself 8 08-25-2016 09:44 AM
Outer Fairing screw hole stripped motosig102 Paint & Bodywork Section 37 08-02-2016 11:47 PM
Fairing attachment screw stripped out. Straitline Troubleshooting for Road Glides 11 08-10-2014 01:49 PM
Stripped Fairing Screw Hole EasternSP Paint & Bodywork Section 10 09-13-2012 11:40 PM
Stripped holes pte359 Paint & Bodywork Section 7 08-03-2011 08:14 AM
