Help identifying vibration please.. - Road Glide Forums
 2Likes
  • 1 Post By Bleachey
  • 1 Post By reds4
post #1 of 7 (permalink) Old 07-15-2016, 03:33 PM Thread Starter
cookie114's Avatar
Ok, last month I began hearing a clanking noise coming from what I thought was primary. Around the same time I also picked up a weird vibration (buzzing) between 2700-3000 rpm. I found out the clanking ended being nothing more than a really loose muffler clamp left side so it sounded like the primary. So I fixed that amd no more clank but I still have this aggravating vibration. Like stated before it comes on @2700-3000 rpm give or take. Its more of a buzz and will almost make the bottoms of feet and inside hands tingle from the buzzing vibration. I feel it most in tje grips/floorboards. Where should I begin? ??
BTW--- Stealership said they felt nothing
2013 FLTRX, stage 1 w/vance and hine power duals and rinehart slipons, TTS mastertune and some other odds and ins. Long ways to go
cookie114 is offline
post #2 of 7 (permalink) Old 07-15-2016, 04:20 PM
Bleachey's Avatar
Let me guess, "They all do that"
cookie114 likes this.
2011 Road Glide Ultra
Bleachey is offline
post #3 of 7 (permalink) Old 07-15-2016, 07:36 PM
When you tighten the clamp..heat shields touchin anything is there another mounting point for the pipe on a '13? Something conducting the vib, the other side maybe. When you get past the footboards and all hard mounted the front mtr mount is last,
You know if was your excuse to spent so much time in the garage during the winter (tightening up) your busted.
reds4 is offline
post #4 of 7 (permalink) Old 07-16-2016, 11:41 AM Thread Starter
cookie114's Avatar
One other thing that I forgot to mention is that when its in that specific rpm range you can look at the rpm/speedo and the numbers actually blur a bit from the vib.
post #5 of 7 (permalink) Old 07-16-2016, 12:08 PM
Check motor mounts and the mounts at the trans.and swingarm,when they get all the rubber worn down it's metal to metal.
steve2100 is offline
post #6 of 7 (permalink) Old 07-16-2016, 12:11 PM
Smarty's Avatar
The first thing I would look at is the mounting bracket back on the saddlebags. Sometimes the muffler will slide back and be rubbing on the metal mount that has the rubber isolator in it.
2016 RGS Black Quartz
Smarty is offline
post #7 of 7 (permalink) Old 07-16-2016, 01:05 PM Thread Starter
cookie114's Avatar
Appreciate the suggestions! Gonna start checking the thing's that I can
Need help identifying existing suspension on a used bike. ZX2BY2U Suspensions 10 09-07-2017 09:29 PM
Help Identifying HD touring seat macabra11 Seating: seats, backrests 6 05-20-2017 12:04 AM
Help identifying led ground effect kit Mtguns Lighting 4 03-14-2017 01:04 PM
Help Identifying Head Pipes on 2010 RGC Gixxere *General Road Glide Discussions/Pictures 5 01-21-2015 10:17 AM
Need help identifying this screw. Triplej *General Road Glide Discussions/Pictures 24 06-03-2013 10:55 PM
