Jerky throttle advance - Road Glide Forums
 3Likes
post #1 of 21 (permalink) Old 07-18-2016, 09:56 AM Thread Starter
Hematite's Avatar
When advancing the throttle grip, it moves in a jerky manner. Its not a smooth advance. Anyone know of the source of this problem? The grip has proper end play. Thanks.
2016 FLTRXS Road Glide Special in Velocity Red.
Hematite is offline
post #2 of 21 (permalink) Old 07-18-2016, 10:10 AM
The bike is under warranty, a trip to the dealer may be in your future.
post #3 of 21 (permalink) Old 07-18-2016, 10:18 AM Thread Starter
Hematite's Avatar
It was there once for this problem but adjusting the end play didn't do it. I'm trying to see if there is a fix so I can steer the technician in the correct direction to get it fixed.
Hematite is offline
post #4 of 21 (permalink) Old 07-18-2016, 11:51 AM
Dragon Dude's Avatar
I believe the notchy feeling is coming from your TBW, throttle by wire. I saw a video on this here recently. You might check it out on U-Tube.
Hematite likes this.
Dragon Dude is offline
post #5 of 21 (permalink) Old 07-18-2016, 12:22 PM
gorillaman's Avatar
Did you change your grips??
2016 FLTRU Vivid Black
gorillaman is offline
post #6 of 21 (permalink) Old 07-18-2016, 02:18 PM Thread Starter
Hematite's Avatar
No, it still has the excessively sticky rubber stock grips. I did hear that it might be the rheostat on the handlebar that could be the source. I'll have to look for the video.
Hematite is offline
post #7 of 21 (permalink) Old 07-18-2016, 02:25 PM
UT_Larry's Avatar
Just a thought. Is it smooth when not running & jerky when running? I went from carb to tbw took me a while to get adjusted to the response. Not saying that's the problem.
UT_Larry is offline
post #8 of 21 (permalink) Old 07-18-2016, 02:29 PM Thread Starter
Hematite's Avatar
It's equally as bad running or not.
Hematite is offline
post #9 of 21 (permalink) Old 07-18-2016, 05:53 PM
gorillaman's Avatar
If it a definite notchy click, click, click and you kinda feel it at the end of the grip... It is the TBW assembly
p/n:32700050
#11
post #10 of 21 (permalink) Old 07-18-2016, 10:20 PM Thread Starter
Hematite's Avatar
Hmm, the grip seems very loose where it enters the housing so it may very well be the TBW. It's regrettable if the nature of the TBW is not smooth. Disappointing.
Hematite is offline
advance the song CR3999 *General Road Glide Discussions/Pictures 7 05-22-2016 02:07 PM
Andrews/Woods 4* degree cam advance gear Eshaw301 Engine Related 3 04-29-2014 05:07 AM
Ignition advance and dwell 4getNo1 ECM/Fuel Management systems 8 04-17-2013 02:48 PM
Advance Carbon Composits (ACC) Helmet Recall MarAgt *General Road Glide Discussions/Pictures 2 04-05-2010 07:18 AM
