no power - Road Glide Forums
  • 1 Post By gsbuick65
post #1 of 9 (permalink) Old 07-26-2016, 12:04 PM Thread Starter
gsbuick65's Avatar
no power
I pulled my handlebars off to swap them and tighten my bearing, started putting it back together turned key on and no power, i checked all the fuses but most have no power, think only the 40amp did. the key cylinder seams to turn as it should. i ended up straightening them instead of swapping, avon is out of heated grips didnt want to put em back on without them.
and i cant find where the wire connector from the acc switch plugs into.
gsbuick65 is offline
post #2 of 9 (permalink) Old 07-26-2016, 12:45 PM
hoosierboarder's Avatar
I would take your ignition back out & retry the installation. Sounds like you don't have it it correctly.
'09 Road Glide
hoosierboarder is offline
post #3 of 9 (permalink) Old 07-27-2016, 05:17 AM
Do you have headlights / turn signal power? I'm just curious if you're having the same issue I'm having. I also removed my ignition. I have no power what so ever. Only thing I see getting power is when I press the odometer button I can see the mileage light up and theft light blinking.
All my fuses are still good, don't have a way to check if they are getting power or not.
2007 RG FLTR
dinggus is offline
post #4 of 9 (permalink) Old 07-27-2016, 08:12 AM
You may need to use a flat blade screwdriver to clock the ignition tumblers.( usually one click to the left for me) Then reinstall the ignition.
'09 Road Glide
post #5 of 9 (permalink) Old 07-27-2016, 12:29 PM Thread Starter
gsbuick65's Avatar
ill try that again, but the switch went on all the way and turned like normal. got any idea where the wire from the accessory switch plug into? i can seam to find the connection, wouldnt think that would be the problem.
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
post #6 of 9 (permalink) Old 07-27-2016, 12:32 PM Thread Starter
gsbuick65's Avatar
dont think so, i didnt check odo button, i will tonight
post #7 of 9 (permalink) Old 07-27-2016, 03:32 PM
Let me know if your lights are working.
Because right now, if I switch the ignition switch on, I don't even hear the fuel pump activating and the gauges resting.
2007 RG FLTR
dinggus is offline
post #8 of 9 (permalink) Old 07-27-2016, 05:37 PM Thread Starter
gsbuick65's Avatar
yep that's what mine is doing, I can push odo it will give me reading, other than that nothing works
post #9 of 9 (permalink) Old 07-27-2016, 09:32 PM Thread Starter
gsbuick65's Avatar
it was the ignition switch, I sprayed grease in it to make the shaft go in as it was making a noise when I turned it well guess it got on the contacts, I took it off and sprayed it with contact cleaner now it works
hoosierboarder likes this.
15 FLTRX Vivid Black............No Security & No ABS maddmoe Road Glide Builds-Document your builds HERE --NEW 135 08-28-2016 12:30 AM
NO OIL and no idiot light?? motodrummer Troubleshooting for Road Glides 16 06-18-2015 09:48 PM
Passenger floorboard mounts. No spring, no ball. Mounts only.40.00 shipped neverdone Sold 1 05-13-2014 06:57 PM
No 6th gear light, no cruise scsharp2260 ECM/Fuel Management systems 5 01-17-2013 02:14 PM
No Cruise, No Brake Lights , engine light and lots of codes DonJulio Troubleshooting for Road Glides 4 07-24-2011 05:02 PM
