TBW Issue - Road Glide Forums
post #1 of 59 (permalink) Old 10-25-2010, 01:28 PM Thread Starter
TBW Issue
I have an 08 RG with TBW. I was 150 miles from home when i went to start my bike after a 30 minute stop and it started right up but when i went to use the throttle NOTHING! all the bike did was idle. Before i decided to s___t myself i shut the bike off and started it again and the throttle worked correctly. No problems on the way home. I had changed my handlebars and did the internal wiring thing the day before and i was wondering if i might have done something like pulled a wire loose. Any insight on this would be appreciated.
TC39 is offline
post #2 of 59 (permalink) Old 10-25-2010, 08:18 PM
Roadie09's Avatar
Check to see if any codes were thrown on the odometer read-out. Clear the codes and see if anything new pops back up. Sometimes a code will pop up about the throttle position sensor when it is unplugged (mainly if you did not disconnect the battery prior to installation). Just something to check, it may or may not have caused your problem.
Roadie09 is offline
post #3 of 59 (permalink) Old 10-26-2010, 12:07 AM
CHAINSAW's Avatar
From what I have heard, his is a common problem, and my bike trip last weekend it did it to me 6 times in 1500 miles.
When we were sitting along side the road, I called my dealer, a buddy called his dealer. They both had us run through the diagnostic check with the odometer reset button, and cleared the codes. It still would only stay in the limp home mode. We gave up, and called the nearest HD dealer that was 30 miles away from us. They told me to smack the end of the grip and try again. It worked and ran fine for another few hundred miles. Sometimes I would just shut the bike off, start it and it would be fine again.
They tell me it happens alot, but this winter Im tearing into mine and replacing the TBW assembly in the handlebars. Im also going to eliminate the plug thats inside the bars and hard wire it directly under the fairing. This is a bug with the TBW, and I guess there isn't enough uproar yet from HD owners that the MOCO wants to deal with it. It is a problem, and needs to be corrected because going 75 mph down the interstate, and you lose all power,.... is not safe.
If I seem to find out the cure, I will share, but I have yet to find one and your not the only one its happening to.
Oh, and 1 other guy on the trip had it happen to him as well. He rides a 2010 Ultra Limited.
Such is the rule of honor.
CHAINSAW is offline
post #4 of 59 (permalink) Old 10-26-2010, 07:32 AM
Bluzmn59's Avatar
I call BS on the dealers for telling you it is common. They need to fix that for you. I have now had three TBW bikes and my wife has 10k miles on her 2010 SG and I have never experienced that issue. Something is wrong.
Life is hard. It's really hard if you're stupid.
1959 FLHF
2007 FLSTSC
2011 FLTRU
Bluzmn59 is offline
post #5 of 59 (permalink) Old 10-26-2010, 09:04 AM
Corrupted's Avatar
Remove the connector at the throttle body for the FBW. If you plug it off/on about 5 times it will wipe the connection clean if that is what it is. If that helps clean it good and use a small amount of dielectric grease on it to keep any moisture out.
I have heard a lot of problems on other forums about this issue.
You only need to be 10% smarter than the thing your working on!
Corrupted is offline
post #6 of 59 (permalink) Old 10-26-2010, 10:15 AM Thread Starter
Good suggestions
Thx for the help Folks. I'll try your suggestions. It really pisses me off the Harley can't get their act together. Guess i'm gonna take the faring off again and check all the connections and wires. Thats ok cause i bought the bike to take it apart not ride it! Thx again for the help.
TC39 is offline
post #7 of 59 (permalink) Old 10-26-2010, 08:31 PM
Roadie09's Avatar
I would not start blaming HD so soon, you did say YOU changed the bars and did internal wiring. I have internal wiring and have done it several times on other bikes and in my opinion, it is just a problem waiting to happen. There is a lot of pulling going on during installation that was never intended.
Roadie09 is offline
post #8 of 59 (permalink) Old 10-26-2010, 11:58 PM
CHAINSAW's Avatar
Mine did it again today on the way to the gas station. After I left there, I rode 30 miles to my dealer and talked with the mechanic and parts manager.
A new one is on the way, covered under warrenty. They have replaced 3 thus far,.. the 3 before me were all on stock handlebars that had never been removed or tampered with.
This time around, Im soldering mine and only leaving the 1 connection inside the fairing.
CHAINSAW is offline
post #9 of 59 (permalink) Old 10-27-2010, 08:52 AM
MassHD's Avatar
Happened to me too. Had to limp home from NH. Turned a 2 hour ride into 4 because of the starting and stopping. The dealer replaced it and it's been fine ever since. There should be a re call on the tbw but you know how that goes.
2010 Road Glide Denim Black
ABS Cruise Factory Security, Black D&D 2 into 1
Firecap's Arc Amp 125.2, 4- Hertz 6 1/2" Speakers
PYO Bars, CVO Rear Fender, KW Wrapper Front Fender
"Burn Rubber Not Your Soul"
MassHD is offline
post #10 of 59 (permalink) Old 10-27-2010, 09:18 AM
How many miles were on your bike when this problem showed itself? Thanks.
reeder is offline
Stock green TBW to CVO TBW? hd4cruzin Controls & Handlebars 12 02-17-2018 12:34 PM
Handlebars TBW to non-TBW HelzBelz Controls & Handlebars 3 10-17-2016 10:47 PM
TBW issue CGURRO Controls & Handlebars 5 07-12-2016 10:52 PM
TBW vs. Pre-TBW Halstem1 Controls & Handlebars 7 12-18-2013 02:13 PM
