Check Engine & Battery Lights?? - Road Glide Forums
post #1 of 4 (permalink) Old 08-10-2016, 09:01 PM Thread Starter
Got on the bike started it up ,, let it warm up and away I go NOT ,, I didn't even make it to the Highway before my Check Engine Light & Battery Light came ON .. Looked at the gauge and only charging to about 11 Volts .. So I go back home hook up the battery tender ,, wait a few hours and start the bike in the garage ,, all seems to be good charging about 14 volts & No Lights..Forgot to add that the battery tender was hooked up before I started and the light green .Where do I need to start looking?? The bike is a 2012 Road Glide Ultra
George W is offline
post #2 of 4 (permalink) Old 08-10-2016, 11:03 PM
I had exact problem you described. Replaced voltage regulator and all has been good for about a year now.
drnovaman is offline
post #3 of 4 (permalink) Old 08-11-2016, 12:33 AM
hd4cruzin's Avatar
This just happened to a friend of mine in Canada last week. Turned out to be the Stator.
Good luck
2012 FLTRX BBP
hd4cruzin is offline
post #4 of 4 (permalink) Old 08-11-2016, 01:35 AM
EODHOG's Avatar
Send a message via Yahoo to EODHOG
Check the charging output and see what you get.
Freedom isn`t free. If you can read this, thank a Teacher. If it`s in ENGLISH, Thank a VET! The right to keep and bear arms shall not be infringed.....
EODHOG is offline
Battery - Check Engine Replicated 3 times Paul's Road Glide Troubleshooting for Road Glides 14 09-12-2014 05:59 PM
Check Engine Light and Battery Light following Jackpot 2-1-2 install PearlBlueUltra Troubleshooting for Road Glides 9 06-15-2014 03:59 PM
check engine and charging lights come on. 06glider Troubleshooting for Road Glides 0 01-29-2014 02:28 PM
check engine and battery light drmudd Troubleshooting for Road Glides 11 04-20-2013 01:08 PM
New Bike - Engine & Battery Light pscan5150 Troubleshooting for Road Glides 15 06-08-2012 05:02 PM
