Worn alternator rotor causing loose compensator - Road Glide Forums
post #1 of 2 (permalink) Old 08-22-2016, 02:53 PM Thread Starter
Figured Id share this, did a quick search and could not find it posted anywhere.
If you're having loose/noisy compensator issues check the alternator rotor face while you're in there.
I had knocking noise coming from the primary area for a while and I was having the starter stall, and loud clunk when you shut the bike off., etc. I just did the SE comp upgrade/fix about a year ago.
Anyways I called a mechanic friend and he said to check the alternator rotor for wear. Sure enough it had a deep grove worn in it, and it was enough to unload the spring pack and cause the noise, 62kmiles. The comp nut was still tight.
2012 FLTRX
Sideways is offline
post #2 of 2 (permalink) Old 08-22-2016, 02:54 PM Thread Starter
More pics, old rotor and new one.
2012 FLTRX
Sideways is offline
New Compensator or Compensator eliminator mrmoto95 Engine Related 11 03-28-2018 07:10 PM
WTB alternator rotor 30041-08 teeboz Wanted! (Buy or Trade) 0 12-10-2016 12:44 PM
Higher output alternator TC308 Troubleshooting for Road Glides 8 07-12-2014 07:22 PM
Rear brakes worn out 14k. Hot rotor seahoch Troubleshooting for Road Glides 11 04-06-2014 12:30 PM
Brand new never worn Ladies Tourmaster denim jacket RaceBizz Miscellaneous for Sale 1 01-09-2013 05:53 PM
