Lost communication with ecm - Road Glide Forums
post #1 of 3 (permalink) Old 08-29-2016, 05:47 AM Thread Starter
RFG7680's Avatar
And speedo.
I flashed a new map this morning. About 5 minutes after I left for work no dash. No gauges at all. Speedo stuck at 60. Tach at 2k.
Checked trouble codes. Lost connection between ecm. Lost connection with Speedo. I went back to my old map and was able to clear the ecm codes it won't clear the Speedo codes.
Fuse? FP3?
RFG7680 is offline
post #2 of 3 (permalink) Old 08-29-2016, 09:33 AM Thread Starter
RFG7680's Avatar
I'm not thinking the 2 are connected. When you flash the tuner I assume it throws that code. Just clear it because it's a non issue. It has not come back since I cleared it. But the Speedo won't go away. Only fuses I found was the small block on the left side. No instrument cluster fuse.
I'll check the connection under the Speedo and tach when I get home.
RFG7680 is offline
post #3 of 3 (permalink) Old 08-29-2016, 02:48 PM
Try unhooking the battery or pulling the main fuse and let the bike sit for a while, doing this may clear out the DTC's that you can't clear.
Harley Touring Advanced Audio Communication Switch Kit 77173-06 93-331-29psi Parts for Sale 0 04-26-2013 11:14 AM
New communication jack installed HUTMO Audio 2 03-16-2013 07:08 PM
FINALLY COMPLETED the Communication System Install HUTMO *General Road Glide Discussions/Pictures 8 06-29-2012 12:21 PM
Communication recommendations? PDGNKG *General Road Glide Discussions/Pictures 16 01-01-2012 07:41 AM
communication headsets ichiban Troubleshooting for Road Glides 6 06-21-2011 01:49 AM
