Head light bezel popped off - Road Glide Forums
post #1 of 5 (permalink) Old 10-28-2010, 04:20 PM Thread Starter
alk
alk's Avatar
Question Head light bezel popped off
I've had this buzz in the fairing going on for awhile now and it stopped the other morning when coming out of the driveway. There's a transition bump from the driveway to the road.. and I heard this clanging. I rode down the street and circled around to find the headlight bezel lying in the road. Luckily it was early morning and no traffic, so it was in one piece.
Since my RG is an '04, do the bezels warp with time? has anyone else experienced their light bezel just popping off? What did you do to keep it attached to the fairing, and yet still be able to remove it for cleaning or light bulb changes?
alk
alk is offline
post #2 of 5 (permalink) Old 10-28-2010, 04:39 PM
JeffBrowning
Guest
Posts: n/a
head light bezel
unfortunatelty its only popped into place i have an 04 and similar problem but i take my bike apart alot doing stuff to it so when im done im buying a new bezel, because mines been in and out way to many times..
post #3 of 5 (permalink) Old 10-28-2010, 04:52 PM
Heat an Cold ?
Sounds like the cooler weather has put the "pool" effect in place? Like George said (It's shrinkage!) LOL, glad ya found it.
Frodoe is offline
post #4 of 5 (permalink) Old 10-28-2010, 08:34 PM
Redfish-Joe's Avatar
I had a little trouble with one side of mine coming loose. What I did it took a candle and warmed the tab up slowly until I could bend it down SLIGHTLY. Gave the tab a little more bite.
Redfish-Joe is offline
post #5 of 5 (permalink) Old 10-29-2010, 12:18 PM
prince's Avatar
The previous owner of mine took off the "bubble" and added a newer style bezel without the clear lens. When I took the outer fairing off to replace a gage bulb I looked at my bezel because it seemed loose. The suggestion above to heat the tangs to get a little more bite seems like the right thing; the designed attachment is "cheezy" at best.
2005 FLTRI
prince is offline
Corner of inner fairing is popped out. Looking for suggestions on a fix USMCEOD Paint & Bodywork Section 3 12-02-2015 09:17 PM
Popped my fairing cherry Taco Bruiser Lighting 13 06-24-2013 05:28 PM
Popped cherry on 1000 mile maintenance Methos1979 Do-IT-Yourself 10 11-14-2012 05:19 AM
Sinister Pissed Off Head Lite Bezel Pic Installed Neano62 Lighting 43 08-03-2012 08:28 AM
Head Light Bezel Fix for Earlier Models zman Lighting 3 02-21-2012 08:24 AM
