Starter Hesitates - Road Glide Forums
post #1 of 2 (permalink) Old 11-13-2016, 01:20 PM Thread Starter
Ironhorse's Avatar
Starter Hesitates
What would cause my starter to hesitate when engine is hot? No hesitation at all when cold.
Thanks
Ironhorse 2015 RGS Vivid Black
Ironhorse is offline
post #2 of 2 (permalink) Old 11-13-2016, 02:35 PM
BlazingSaddle's Avatar
Someone with a little more knowledge will soon chime in, but in the meantime I'll provide my .02
You don't mention whether the problem always happens or whether it's intermittent. I'll guess you've already checked your battery connections. It wouldn't hurt to make sure ALL connections are tight, not just on the battery. Check both ends of the ground cable, as well as leads to starter.
You can also try jump starting it with your car after you've run the bike and see if it's still slow to start when hot. If it cranks right up, you can more than likely rule out the starter (unless it's an intermittent problem). If not, could be the battery.
Whatever you do, don't start the car while it's hooked up to your bike.
BlazingSaddle is offline
Hesitates when hot 08gezzer Troubleshooting for Road Glides 13 07-11-2013 05:47 PM
Starter Hesitation & Fuel Range reading Cotton Hill Troubleshooting for Road Glides 4 05-27-2011 08:37 AM
Rebuild silenoid or replace starter? krgs2k Troubleshooting for Road Glides 6 04-20-2011 04:01 AM
Spyke starter issues Hotroadking Troubleshooting for Road Glides 2 02-15-2011 12:05 PM
Starter Marks07RG Equipment-RG 1 09-21-2010 05:42 PM
