Shuts off at idle - Road Glide Forums
post #1 of 9 (permalink) Old 11-04-2010, 01:52 AM Thread Starter
Shuts off at idle
So got new problem that it wont run or start at idle but twist the throtle and it will run at 1500 RPM, allready changed the crank sensor due to a miss when running about 2200 RPM, throttle position sensor due to flat spot. Battery, coil, wires, plugs, and getting fuel thats all good anyone elce have this problem? Thanks for help
dgb road is offline
post #2 of 9 (permalink) Old 11-04-2010, 02:36 AM
jbrushoe's Avatar
Sounds like the TPS but you changed it... Is it showing any codes? What year bike?
06 Shark Fire Red Pearl
1997 FLSTS > looking for a new home
Jim
jbrushoe is offline
post #3 of 9 (permalink) Old 11-04-2010, 08:22 AM Thread Starter
No trouble codes, strong spark when trying to start, it just started the problem on day or didn't start that day. Its an 04 with 95, 510 cams, SERT this was all done last year all ready put twenty thousand miles on motor without any problems
dgb road is offline
post #4 of 9 (permalink) Old 11-04-2010, 09:16 AM
Redfish-Joe's Avatar
Check your intake seals. With it warmed up and running spray a small shot of WD40 on the intake seals. If the motor smooths out for a few seconds then your seals need to be replaced. Hope this helps.
Redfish-Joe is offline
post #5 of 9 (permalink) Old 11-04-2010, 11:45 AM
jbrushoe's Avatar
Like Joe said check intake for air leaks if that checks out it could be your idle air control. But usually they will throw a code but not always. One other thing your throttle stop could be out of adjustment.
Jim
jbrushoe is offline
post #6 of 9 (permalink) Old 11-04-2010, 12:33 PM
I swear, I couldn't think of the IAC this morning for anything. Now if memory serves me right, I think there is a small port in the top of the throttle body near the front. This gets stopped up some times. A little spray carb cleaner will clear it out. You can also clean the IAC motor with it too.
post #7 of 9 (permalink) Old 11-04-2010, 01:46 PM
jbrushoe's Avatar
LOL... ya that happens with age, I get those dam brain farts all the time.. Aw $hit there I go telling on myself again..
Jim
jbrushoe is offline
post #8 of 9 (permalink) Old 11-06-2010, 09:43 AM Thread Starter
Thanks for the help, replaced the idle air control unit and cleaned the air port. When I checked it the valve was not opening for air to get by, time to ride
dgb road is offline
post #9 of 9 (permalink) Old 11-06-2010, 11:18 AM
jbrushoe's Avatar
Glad you got it running right again, ride safe...
Jim
jbrushoe is offline
Bike shuts off at 5000rpm milkman48 ECM/Fuel Management systems 5 07-08-2017 11:34 PM
Bike Shuts Off harlydavdsn Engine Related 12 08-09-2015 12:16 PM
Trouble with install of kenwood headunit and kenwood amp. Shuts off... Mikie Audio 0 08-03-2015 12:24 PM
2003 Engine Shuts Off While Riding EZ GLIDER *General Road Glide Discussions/Pictures 14 06-13-2013 06:35 PM
Shuts down after 6- 10 miles azrenegade Troubleshooting for Road Glides 8 08-11-2011 11:30 PM
