Rear Drive seals on 1982 FLT! - Road Glide Forums
  • 1 Post By AzHogRider
post #1 of 8 (permalink) Old 12-10-2016, 01:07 PM Thread Starter
Exclamation Rear Drive seals on 1982 FLT!
OK so I ran into bit of a problem on my 1982 FLT. The enclosed rear drive chain needs some new seals. My local really good HD dealer can't even find the part numbers. I had to take it apart to replace the really shot rear brake rotor.
Anyone got any clue on what to do about the seals?
I suppose I can just run an open chain or switch to belt drive. The belt drive will be pretty expensive.
Maybe I could coat the original seals with silicone goo and reassemble.
1982 FLT Virgin unmolested barn find.
1983 FXDG 80th Anniversary AKA Willie G Disc Glide, 10.5 to 1, Andrews B grind, 2002 Fat boy carb, Barnett Clutch, drag pipes.
2003 FLTSCI Black and Silver converted with Motor Trike Kit plus HD tour pak, 88 inch, HD 204 Cam, Vance & Hines mid shots.
AzHogRider is offline
post #2 of 8 (permalink) Old 12-10-2016, 01:59 PM
A quick search __oem 25414-82-DL
I'd cut/fab before ever silicone
$16.95
reds4 is offline
post #3 of 8 (permalink) Old 12-11-2016, 04:48 PM Thread Starter
Very cool, I will now chase that part number.
post #4 of 8 (permalink) Old 12-11-2016, 10:06 PM
JacktheBagger's Avatar
Lover of enclosed chains , they last forever .. Don't ask me how I know this , but when you re install do not over torque the axle or you will get the seals leaking again , not that I ever did this mind ewe ..
So curious , what are you using for tires now a days ?? Is there still the god awful D291 with that funky lip and the D491 ??
2011 Ultra
JacktheBagger is offline
post #5 of 8 (permalink) Old 12-13-2016, 04:01 PM Thread Starter
Well the tires seem to be in pretty good shape. I really am just going to flip this one and I will warn the new owner that they are pretty darn old.
Everything will be torqued with the torque wrench.
The project bike is coming along slow but sure, I had to paint bunch of the "tins" as they were just plan nasty with a couple of hidden butchered up spots and a cracked tour pak. I had to repair those items. Some of the chrome is going out to a local shop.
I have to agree on the chain, it looks like brand-new as do the sprockets.
RGKen likes this.
post #6 of 8 (permalink) Old 12-13-2016, 04:43 PM
RGKen's Avatar
I think it would be cool if you could post some pics of your project. I cant wait to see it when you finish.
2018 FLTRXS
RGKen is offline
post #7 of 8 (permalink) Old 12-13-2016, 11:38 PM
I aint in the market for another , but will be a nice catch for someone ..
2011 Ultra
post #8 of 8 (permalink) Old 12-14-2016, 10:43 AM Thread Starter
Yeah it is real FUGLY right now, Just about stripped down all the way, I think front wheel to change brake rotors will be the last tear down required. I have some snaps but will hold off till I start to make some more progress.
It will make a nice rider when done. Pretty stock really. Motor has good compression and a fresh carb, should run just fine.
Progress on 1982 FLT Barn find. AzHogRider *General Road Glide Discussions/Pictures 7 03-03-2017 11:34 AM
1982 FLT luggage seals needed. HELP AzHogRider *General Road Glide Discussions/Pictures 1 01-19-2017 03:49 PM
1982 mid year flt eddie from chesapeake *General Road Glide Discussions/Pictures 4 09-05-2015 06:40 PM
S&S cam drive vs the new HD cam drive kit jprider4life Engine Related 4 09-04-2015 07:17 AM
2,500 miles - pulled lower fork sliders, should i install new seals/bushings? modot66 Suspensions 8 02-23-2012 10:33 PM
