Speedometer not working... - Road Glide Forums
post #1 of 2 (permalink) Old 02-07-2017, 01:18 PM Thread Starter
Checked for codes, none.
Checked VSS for metal shavings, none whatsoever.
Replaced VSS, no change.
Still lights up but not sure about odometer changing, wasn't watching.
Do I have a grounding problem or speedo shot?
Any help is appreciated.
2006 Black Pearl
Grommet is offline
post #2 of 2 (permalink) Old 02-08-2017, 09:29 AM
It' hard to say if the speedometer is shot or not. The best way to check the speedometer would be to put another speedometer in and see if everything works. If you have a friend that has a touring model bike you may be able to swap out speedo's just long enough to see where the problem is.
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
Right blinker does not work, red key is on in speedometer [email protected] Lighting 4 06-12-2018 09:46 AM
Gauges, indicators, speedometer, tachometer all quit working Hog Happy Active Military and Veteran's group 5 10-12-2016 05:32 PM
Cruise Not Working Hullhorr Troubleshooting for Road Glides 27 03-22-2011 09:39 PM
Battery died, now speakers not working!!!!!! schnid72 Audio 11 02-12-2011 07:33 PM
