Cruise control not working - Road Glide Forums
 4Likes
post #1 of 22 (permalink) Old 03-25-2017, 02:51 PM Thread Starter
Little red light comes when i flip the on switch but nothing happens when i try to use it
any ideas ?
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #2 of 22 (permalink) Old 03-25-2017, 03:12 PM
Mike U's Avatar
CPY84 check and make sure that your brake light is not staying on.
If it is that means the cruise control won't work.
If that's what's happening check the front brake lever and the switch inside the housing.
Hope this helps.
papayak likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 22 (permalink) Old 03-25-2017, 03:33 PM
Thermodyne's Avatar
It's diagnosed using the onboard diagnostic mode.
Basically it checks the function of the hand switch, roll off function and the brake switches. If that doesn't locate the issue, and there are no codes, then you'll need a breakout box to run the second level diagnostic.
Many of the possible issues will also set a trouble code, so I'd prolly check the codes first.
Thermodyne is offline
post #4 of 22 (permalink) Old 03-25-2017, 05:38 PM Thread Starter
WELL as stated the brake light is stuck on so now whats next ? i read somewhere that the brake light switch is bad and has to be replaced ?
2011 RG ULTRA.
CPY84 is offline
post #5 of 22 (permalink) Old 03-25-2017, 05:49 PM
08Zinc's Avatar
One bike I owned had an adjustment for the rear brake light. Check the owners manual, maybe yours does as well. (That would be no cost and quick if that's it)
Blessings, Zinc -
08Zinc is offline
post #6 of 22 (permalink) Old 03-25-2017, 06:15 PM
bucketlisthd's Avatar
You have to figure out which brake is causing the problem. Try pushing the hand lever forward and see if that works.
bucketlisthd is offline
post #7 of 22 (permalink) Old 03-25-2017, 07:26 PM
If the brakes are sticking on, 9 out of 10 times it's the front brake light switch broken, at least on pre 15 RGs. That switch is very delicate and not cheap if you buy it from the dealership. There are ways to fix it, you can do a search on this forum, (that's how I did it a few years ago), then check eBay for a reasonably priced replacement. What year is your bike?
post #8 of 22 (permalink) Old 03-25-2017, 07:38 PM Thread Starter
2011 RG ULTRA.
CPY84 is offline
post #9 of 22 (permalink) Old 03-25-2017, 08:31 PM
mjsdouble's Avatar
Hopefully it's your rear brake switch. Happened to my wife's (2007 SG). That would be an easy fix.
mjsdouble is offline
post #10 of 22 (permalink) Old 03-26-2017, 07:11 AM Thread Starter
ok just followed the directions from the sticky.
3 codes which still doesn't tell what to fix.
p0572-brake switch low
c1094-front brake switch always on
c1214- rear brake switch always on.
so can any one tell me what to fix ? lol.
and yes the fluid is fine.
2011 RG ULTRA.
CPY84 is offline
Neutral light on cruise not working and gear indicator not showing Xman247 Tools and Garages 7 08-11-2018 11:09 AM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
cruise contol stopped working dhhen Troubleshooting for Road Glides 21 04-17-2012 03:29 PM
Cruise control working intermittently? motodrummer Controls & Handlebars 4 03-23-2012 07:31 AM
Cruise Not Working Hullhorr Troubleshooting for Road Glides 27 03-22-2011 09:39 PM
