Resisters - Road Glide Forums
post #1 of 4 (permalink) Old 03-26-2017, 11:07 AM Thread Starter
taoist's Avatar
Resisters
What size resister do you need to install to get a turn signal relay to activate ? Turn signal bulb is only drawing 2 watts and is not recognized by the relay.
Thanks for any help.
2006 Black 95 cu in Dyna Street Bob
2017 Black Road Glide Special
taoist is offline
post #2 of 4 (permalink) Old 03-27-2017, 10:31 AM
If you're using the stock lighting then you don't need any resistors so you may have another problem. If you put in L.E.D bulbs the a resistor box may be needed to get the turn signals to work right.
post #3 of 4 (permalink) Old 03-27-2017, 11:08 AM
UT_Larry's Avatar
15+ should not need them 13- use a load equalizer.
UT_Larry is offline
post #4 of 4 (permalink) Old 03-27-2017, 11:43 AM
Harkon's Avatar
Be ready, just a resistor will get really hot.
ROT is a 50W 6ohm resistor. It goes across the load (in parallel with the LEDS). remember it's going to get about 25-30W hot. With equal on/off signal times it will be about 1/2 that, but still likely warm enough to melt any touching plastic over the long haul.
2012 FLTRU, Alley Cat AC, Jackpot Super Duals header, Jackpot HiRoller Mufflers, PV Tuner || 2013 CRF450X FMF Powercore 4 HEX, uncorked, jetted
Harkon is offline
