Idle speeds up when hot - Road Glide Forums
  • 1 Post By nytryder
post #1 of 7 (permalink) Old 04-05-2017, 11:01 AM Thread Starter
When the motor is hot my idle speeds up when stopped in traffic or waiting at red lights. I can give it gas and it slows to normal but after a few seconds it speed up again. Any ideas of how to fix it?
Gary
Gmarcum13 is offline
post #2 of 7 (permalink) Old 04-05-2017, 11:11 AM
Stoic Joker's Avatar
Folks will probably need more details to work with:
Year
Mileage
How modified is it
How high does the idle go...
...More stuff that might be useful.
Scarlet Red 2010 Road Glide Custom named Trixie - She's a flashy little minx..
Basic black 1981 Tour Glide Classic named Alice - She's a sleeper project.
Stoic Joker is offline
post #3 of 7 (permalink) Old 04-05-2017, 11:34 AM
Do you have a Rushmore ('15+) bike? If so the EITMS is probably coming on and shutting down the rear cylinder. Press the INFO button on your right hand controls and it should bring up a screen that shows EITMS. If it says "ACTIVE" when you notice the issue, that is what you are experiencing. Good news is you can turn that function off if you desire.
macabra11 is offline
post #4 of 7 (permalink) Old 04-05-2017, 11:49 AM Thread Starter
Yes it's a '15 R G Special. I'll try your suggestion this afternoon. The "service advisor" at HD said he'd never heard of this issue and set me up for 8am Sat. It's till under warranty but I'd just as soon fix it myself rather than give it up for a whole day.
Thanks,
Gary
post #5 of 7 (permalink) Old 04-05-2017, 11:52 AM
WTFranz's Avatar
And you can actually watch it turn from "Enabled" to "Active" and feel the difference. To change from Enable to Disable Turn your throttle in reverse direction till stop point and hold for 10 seconds...
Mazikeen - 2016 Road Glide Special from Arizona
WTFranz is offline
post #6 of 7 (permalink) Old 04-20-2017, 04:05 PM
nytryder's Avatar
With the engine off, turn the ignition on for 5 seconds then off for 5 seconds. Do this 4 0r 5 times. many times this will solve the problem. It's caused by hitting the run off switch to the off position while engine rpm is above normal idle. hope this helps.
ironmark likes this.
2015 FLTRUSE
nytryder is offline
post #7 of 7 (permalink) Old 04-21-2017, 11:06 AM
Cycling the ignition switch on then off 5 0r 6 time usually help idle problems. A ignition cycle is turning the switch on then waiting for the engine light to go off the turn the ignition switch off. If that doesn't help then you may have a faulty engine temp sensor.
Rough idle, seems hot Lucky Engine Related 4 07-28-2015 01:09 PM
hot idle problem firefighterkp Troubleshooting for Road Glides 4 06-11-2014 09:02 AM
rattle noise at idle after hot start. Bush pilot *General Road Glide Discussions/Pictures 19 05-30-2014 06:43 PM
It would not idle hot?? allbrand Tech Area 3 12-12-2012 01:00 PM
won't idle hot allbrand Troubleshooting for Road Glides 10 11-13-2012 05:53 PM
