Fuel gauge, air temp gauge inop - Road Glide Forums
post #1 of 2 (permalink) Old 04-17-2017, 06:00 PM Thread Starter
Well, like the title says, fuel gauge goes to full and stays there when ignition switches on, I'm assuming a bad wire somewhere, so where do I start hunting it down? Also the air temp gauge is erratic, and seems to coincide with throttle input, the air gauge is more of a nuisance but I'd really like to have a working fuel gauge so I don't spend time walking lol. Bike is an 03 injected model.
Crcarnage87 is offline
post #2 of 2 (permalink) Old 04-17-2017, 06:19 PM
Thermodyne's Avatar
Get a wiring diagram. Then start checking circuits. Fuel gauge get battery voltage at key on. Fuel sender supplies a variable ground to move the needle. Start by checking for voltage at the sender wire at the sender. If you see battery voltage, ground it and see if the needle moves.
Beyond checking the voltage at the gauge, I got nothing on the air temp. But it sounds like a ground issue.
Thermodyne is offline
Installed bars now heated grips are inop 05Quadrasteer Controls & Handlebars 8 03-02-2017 08:28 PM
using air temp gauge for air pressure jw robey Suspensions 4 06-18-2016 05:54 AM
Oil temp gauge wanted (gauge only, not full kit" SickRick Wanted! (Buy or Trade) 0 04-08-2013 02:54 PM
Another 2004 Cruise Ctrl inop Gayton81 Troubleshooting for Road Glides 4 11-19-2011 03:58 PM
What would I have done without my Air Temp Gauge? jimmyray11349 *General Road Glide Discussions/Pictures 28 07-17-2011 09:50 PM
