Transmision problem - Road Glide Forums
 2Likes
post #1 of 12 (permalink) Old 05-03-2017, 06:18 AM Thread Starter
Bandit 7's Avatar
Transmision problem
Checking to see if anyone else has had or ran a cross this issue I'm having. I have a bad rattling sound coming from the trans side cover when in neutral with the clutch engaged, rattling gets loader and faster with RPM increase. When I pull in the clutch lever to disengage the clutch the rattling goes away no matter the RPM. I used a stethoscope to isolate the sound, it's coming from directly behind the side cover. The further I move the scope away from the side cover towards the primary side the sound fades away. I know I have to tear into it to find the problem but just wondering if anyone else has had the issue. I do my own work and have rebuilt a few trannies / installed 6 speed gear sets into 5 speed housings. Your thoughts?
Bandit 7 is offline
post #2 of 12 (permalink) Old 05-03-2017, 08:20 AM
Smarty's Avatar
What year and bike and how many miles on it? Harley's new bikes are notorious for neutral rattle. Put some Redline Heavy Shockproof in it and should cure your problem it that is what it is.
ironmark likes this.
2016 RGS Black Quartz
Smarty is offline
post #3 of 12 (permalink) Old 05-03-2017, 09:14 AM Thread Starter
Bandit 7's Avatar
Transmision problem
2012 RGU 60,000 miles. I never had this rattle before yesterday. Started yesterday on my way home from work. I'm the original owner, bought it new.
Bandit 7 is offline
post #4 of 12 (permalink) Old 05-03-2017, 09:43 AM
Smarty's Avatar
In that case, there could be multiple problems causing this. Unusual normally the compensator noise on these year bikes.
Smarty is offline
post #5 of 12 (permalink) Old 05-03-2017, 09:52 AM Thread Starter
Bandit 7's Avatar
Noise is on the other side. I had to replace the compensator at around 50K
Bandit 7 is offline
post #6 of 12 (permalink) Old 05-03-2017, 10:03 AM
mjsdouble's Avatar
I sent you a PM Bandit. My wife's bike had the same symptoms as yours. The Cluth assembly was replaced and it's been fine since.
mjsdouble is offline
post #7 of 12 (permalink) Old 05-03-2017, 11:51 AM
Thermodyne's Avatar
If the noise is in the right of the trans, then release bearing or trapdoor bearings would be suspect.
And as said above, it could be an issue on the other end of the shaft transferring noise to the trap door.
First thing I would check the the main drive gear bearing. That's the most common failure point.
And any lateral movement on the shafts will probably transfer noise into the trap door, so don't be surprised if you find the issue on the other side.
Thermodyne is offline
post #8 of 12 (permalink) Old 05-03-2017, 12:43 PM Thread Starter
Bandit 7's Avatar
All thanks for all the info and thoughts. I'm going to start the year down tonight and will post here the results. Luckily I still have my old faithful 94 Heritage to ride.
Bandit 7 is offline
post #9 of 12 (permalink) Old 05-03-2017, 01:44 PM
mjsdouble's Avatar
Good luck. I hope it's simple and inexpensive for you.
post #10 of 12 (permalink) Old 05-04-2017, 07:46 AM
The noise could also be coming from the Clutch Hub Bearing, this bearing has had a history of failure and since it is connected to the transmission it would produce sound in the trans.
Shift linkage problem FLTRIder Troubleshooting for Road Glides 24 07-17-2015 08:35 AM
07-08-09 Problem Issues joke *General Road Glide Discussions/Pictures 13 01-17-2011 02:19 PM
OL says Roadie has a Problem JacktheBagger Troubleshooting for Road Glides 11 10-11-2010 08:59 PM
Electrical problem 63riv1 Troubleshooting for Road Glides 4 07-25-2010 09:43 PM
07 stalling problem watchdog Troubleshooting for Road Glides 3 07-07-2010 10:37 AM
