2012 Cruise Control intermittant? - Road Glide Forums
post #1 of 11 (permalink) Old 05-08-2017, 01:53 PM Thread Starter
Jimbosan's Avatar
Question 2012 Cruise Control intermittant?
Need a little help.......
My cruise control won't hold for more than 1 mile at any given time.
Flip the switch and red light comes on, set the speed with the thumb button and green light shows up on gauges.
1 mile later, it just releases. Red light stays on, no codes and light on gauges turns amber.
I can reset it again and it does the same thing........
Any ideas?
Ride it like you stole it! Just watch out for the evil monkey!
Jimbosan is offline
post #2 of 11 (permalink) Old 05-08-2017, 02:35 PM
PanWhenUCan's Avatar
check that your brake lights are not flickering
if you have had your handlebars off it is possible that the switch is not quite seated correctly and sending a brake light signal shutting down the cruise
ironmark likes this.
PanWhenUCan is offline
post #3 of 11 (permalink) Old 05-08-2017, 02:39 PM
if you hit a bump it can shut down, also is your front brake pulls back to the grip it can cause the same problem
post #4 of 11 (permalink) Old 05-08-2017, 02:42 PM
DED HD's Avatar
... and if it is brake switch related, have you had the Brake Light Switch recall performed on your bike?
'10 Red Custom:
DED HD is offline
post #5 of 11 (permalink) Old 05-08-2017, 03:16 PM Thread Starter
Jimbosan's Avatar
No, I haven't had the brake switch recall done yet. Should I have that done first, then start the other troubleshooting?
Jimbosan is offline
post #6 of 11 (permalink) Old 07-15-2017, 08:56 PM
RoadRider's Avatar
Found link that indicates a bad clutch safety switch
https://www.hdforums.com/forum/new-r...indicator.html
I had a problem last year when my cruise would kick out and the gear indicator would drop out and come back on while riding. It just happened again... so I'm taking it to be repaired this week. I'll update when I have a solution.
RoadRider is offline
post #7 of 11 (permalink) Old 07-17-2017, 10:40 AM
Shrug's Avatar
I struggled with that too and it turned out to be the front brake lever not engaging the button switch. I inserted a tiny screw into the back of the lever; problem solved.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
post #8 of 11 (permalink) Old 07-17-2017, 12:34 PM
Bandit 7's Avatar
I had the same problem a while back. My problem was the cruise switch, replaced the switch problem fixed.
Any ideas?
Bandit 7 is offline
post #9 of 11 (permalink) Old 08-13-2017, 12:39 AM
If you have ABS brakes, have the brake fluid checked for water. Had the same problem with my 2013 RGU. Had service done on bike and they found water in the brake fluid. Flushed brake lines and have not had the problem since.
dcphill is offline
post #10 of 11 (permalink) Old 10-03-2017, 09:31 AM
clutch switch failing
I had the same thing happen when I was traveling across Canada...clutch switch was going out, easy replacement and it has worked since.
mcneiljp is offline
2012 Road Glide Cruise Control issues Blademn Controls & Handlebars 3 08-11-2017 08:43 AM
Hawg wired, no bass and display intermittant ironmike666 Audio 4 08-04-2015 09:52 AM
Ground studs/Intermittant charging issue thedrill Engine Related 3 07-17-2014 06:54 PM
intermittant power locks pandrews1 Troubleshooting for Road Glides 9 06-08-2014 10:55 AM
red cruise light, no cruise piggs Troubleshooting for Road Glides 1 05-08-2014 05:47 PM
