electrical issues - Road Glide Forums
 4Likes
post #1 of 12 (permalink) Old 05-09-2017, 12:57 PM Thread Starter
electrical issues
OK so last night I went for gas. Got down the street and radio went out and gas light came on(knew I was ready for gas), radio comes back on for a minute and goes back off and on again and fuel light goes out. Few miles later fuel light comes on and check engine light comes and goes. Got gas and was fine going home. Pulled codes when I got home and had the following, P0563,P1357, sb0563,spb1006,1007 and t b1006,1007 WOW. So it was late didn't check anything but will go over battery connections and check plug connections.Been looking on forum and am leaning towards voltage regulator. bike is 2012 rgu 95000 miles stage 1 no tuner. Any thoughts?
bigdoug1130 is offline
post #2 of 12 (permalink) Old 05-10-2017, 10:00 AM
The VR is a good place to start, the 2012 has had a history of VR issues and there was even a recall issued by HD on the VR on the 2012 models. The p0563 code is a high voltage code and usually the 1st DTC is the problem and the DTC's that follow are secondary DTC's. Clear the DTC's and see if they return and if they do check the VR or just replace it. Replacing the VR is a easy DIY with basic hand tools. Don't forget to check the battery connections too.
Chunk likes this.
post #3 of 12 (permalink) Old 05-12-2017, 09:31 AM Thread Starter
OK checked battery connections ,tight, took voltage reading at stator plug, 21vac at idle. Went for ride and about two blocks from home volt gauge pegs at 16. Returned home bought new voltage regulator and changed. Rode to work this morning and everything looked good. Need a longer ride but I feel good about it. Thanks Ironmark for your input.
post #4 of 12 (permalink) Old 05-17-2017, 02:45 PM Thread Starter
had about 500 trouble free miles then battery and check engine light came on low battery voltage code. took voltage on stator and had [email protected] ,[email protected], and [email protected] Any thoughts, battery or stator going bad ?
post #5 of 12 (permalink) Old 05-17-2017, 03:38 PM
Check your main ground on the MC
post #6 of 12 (permalink) Old 05-17-2017, 09:06 PM Thread Starter
Ok checked and cleaned grounds. Put volt meter on battery and getting 12.46 volts idling, goes up to 12.5-12.6 if I rev it a bit,seems low. If weather permits I'll go for a test ride tomorrow.
sputnik likes this.
post #7 of 12 (permalink) Old 05-17-2017, 09:42 PM
I'm willing to bet your stator is going bad, did you check it for shorts?
post #8 of 12 (permalink) Old 05-18-2017, 07:59 AM Thread Starter
I did, didn't find anything unusual. When a stator goes bad does it go slow or just shit the bed all at once?
post #9 of 12 (permalink) Old 05-18-2017, 09:05 AM
A good battery should be reading 13> volts and not fluctuate much with acceleration.
I doubt you VR is going bad again but you never know. The VR usually are finicky when going bad, very rarely do they just stop working.
Battery mart sells the Big Crank battery for $109 delivered. Same battery as HD sells W/O the badge.
post #10 of 12 (permalink) Old 05-19-2017, 08:53 AM
From my experiences when the stator goes bad the Voltmeter will read normal at when starting the bike cold and then as the bike warms up the voltage will drop below normal and it will keep dropping to a round 10 volts. Since the VR didn't fix the problem the Battery would be a good option to look into. If it's the battery Battery Mart is the place to go. It sound like the charging system is working as it should, the stator problems are pretty obvious but the
VR can be unpredictable,
2015 Electrical issues RodeGlide Troubleshooting for Road Glides 11 10-30-2018 12:24 PM
Electrical issues. Need Help!!! Kooljay Engine Related 6 07-07-2017 12:23 PM
Recurring theme: electrical issues following 14" Malo bar install slowride Troubleshooting for Road Glides 15 12-01-2015 12:23 PM
Amp(s) & Electrical Issues ??? HeatWave Audio 6 02-15-2013 11:28 AM
Possible Electrical Charging issues??? paco ritter Troubleshooting for Road Glides 5 10-05-2012 09:26 PM
